It is currently Sun Apr 05, 2026 2:57 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 76 mikado project
PostPosted: Wed Mar 18, 2009 8:22 pm
p.s. I'd rather talk/bother you guys than the wife and kids :lol:
76 mikado project,mean green
PostPosted: Wed Mar 18, 2009 10:26 pm
with an electric pump the pressure should stay pretty steady
PostPosted: Thu Mar 19, 2009 12:58 am
what about voltage?should that stay constant as well? because it ran fine when we tested it up front with the pump wired directly to the battery.
PostPosted: Fri Mar 20, 2009 5:46 pm
mine is ran off of the ignition fuse under the hood then grounded to the frame so you might try that it turns on with the key and with that weber you might half to run some kind of return system but i got a solution to fix all your problems v8 with a mechanical pump
PostPosted: Mon Mar 23, 2009 12:04 pm
someday i'll have a sbc,not while I'm on unemployment though :lol:
PostPosted: Fri Mar 27, 2009 12:59 pm
that sucks i just got a new job today been looking for 5 to 6 months
PostPosted: Fri Mar 27, 2009 10:11 pm
actually with side work im making a little bit more than before! plus I have more time to work on the luv!!
PostPosted: Mon Mar 30, 2009 11:22 am
thats good at least your not compleatly out of work
PostPosted: Tue Apr 07, 2009 9:43 pm
thanks, just working hard enough to realize I'm not as young as I once was!
PostPosted: Mon Apr 13, 2009 2:26 pm
here is some updates for y'all, I ended up having a bad f.p. relay so I wired it to the fuse box and battery.lowered it just over 2".tore out the home carpet lol, surface rust,they don't salt the roads in oregon.used some naval jelly on the rust and getting ready to wire wheel it down a little and primer.needed a longer kick down cable,auto trans.found one,700 r4 I think.got to fab a mount and spring for that.oh yeah got some buckets out of a vw. they mount weird,the slider mech. must be part of the v.w. frame not the seat,so they wont slide once I get them in but for 27$ it will do. here's some pics.Image
PostPosted: Mon Apr 13, 2009 2:31 pm
couple more,sorry they are so big,I just started using photobucket.Image
PostPosted: Mon Apr 13, 2009 2:40 pm
tried to edit it a dozen f#$^##&g!!! times I give up.
PostPosted: Mon Apr 13, 2009 6:01 pm
Rust, that just looks like a little discoloration. Looks solid. Has anyone tried that POR 15 paint.
PostPosted: Mon Apr 13, 2009 9:48 pm
I looked for some,not too hard,lol but found some that says you can paint over rust at autozone.
PostPosted: Tue Apr 14, 2009 1:24 am
por 15 is awesome stuff... you do have to get rid of existing rust for it to work properly. but once you get it on and it sealed you can put it in the ocean for years and take it out and there wont be a speck of rust
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Tue Apr 14, 2009 10:20 am
ill agree with the discoloration if i could rub on a migic lamp i would wish for those floor pans
PostPosted: Tue Apr 28, 2009 9:01 pm
guess us west coasters are spoiled! got some primerin' done.Image
PostPosted: Tue Apr 28, 2009 9:09 pm
painted the headliner,dropped the front a little more,...
Imagethen rode GO KARTS!!!!Image
PostPosted: Thu Nov 05, 2009 11:45 pm
That is an awesome LUV, I am in the market for one, just joined the site. I was wonderin if you would be willing to tell me how much you paid for it? and maybe do you know an easier way to locate them than the internet?
Thanks
PostPosted: Sat Nov 07, 2009 9:59 am
well I bought it out of portland not running for 200.00$,i then towed it back to eugene which ended up costing about $200.00 after dolly rental,food,gas and a trailer wirering harness for my buddy's truck.I put a new carb on it and bypassed the fuel pump relay and bingo she runs!so all told about $600.00! Either come back to Oregon or have someone pick one up for you here,they are on craigslist all the time,I think we are the luv capitol of the world!!
