It is currently Tue May 26, 2026 7:41 pm
 Post subject: Tune Up?
PostPosted: Tue Jul 29, 2003 12:26 pm
Wondering if y'all gents could kinda run through a simple tune up for me. I've heard about them, but I don't know what is tinkered with in a tune up or how to tinker with it. Many thanks in advance
PostPosted: Tue Jul 29, 2003 1:03 pm
when i think of a tune up:
new plugs and wires, new dist. cap. replace or reset points, new air filter, recheck timing.
PostPosted: Tue Jul 29, 2003 8:34 pm
on top of what larp said, you may also whant to check valve gaping whith a feeler gauge.
PostPosted: Tue Jul 29, 2003 9:37 pm
Don't laugh too hard, but what exactly are points? (Sorry but I don't really know much about engine and engine systems yet) :oops: :oops: :oops: Thanks again
PostPosted: Tue Jul 29, 2003 10:03 pm
Hey man, nobody's laughing here. This is good for you. If you're doing all the work yourself and taking the advice written here you can get some good hands on experiance. It doesn't take too long to figure things out.
PostPosted: Tue Jul 29, 2003 10:43 pm
HAHAHA :P j/k man :wink: .....points are one thing that control the spark . they are located under the dist cap....little thing w/ a round silver colored condensor and 2 contacts...i cant remember what they are suppoused to be gapped at right now. but someone w/ a manual should be able to tell ya.
PostPosted: Wed Jul 30, 2003 12:26 am
Thanks larp, i have a manual so i'll check it out tomorrow
PostPosted: Wed Jul 30, 2003 12:43 am
i cant remeber the gap right now (i did an electronic ignition swap on mine) but i think its .020 or.030. I know the dwell is suposed to be 50*
and hey when ever you have questions just ask here, as a whole i dont think theres a question one of the guys here cant answer.
PostPosted: Thu Jul 31, 2003 10:22 pm
i just did mine and if i remeber right its like .016-.020. change ure rotor if u change ur cap. matt
PostPosted: Fri Aug 01, 2003 12:13 am
Also, if you havent already, replace your fuel filters. Normally you should have 2 on the truck. One up near the engine on the fenderwell and the other one(the one that many overlook) thats mounted between the tank and the fuel pump. You can find it by looking under the bed of the truck forward of the gas tank filler tube.
PostPosted: Sat Aug 02, 2003 8:35 pm
Just a quik question, anybody know why there's normally 2 fuel filters? When I found that I just took it off and changed the one by the engine. It's a pain in the butt to try and get at the one down by the fuel tank...
PostPosted: Sat Aug 02, 2003 9:10 pm
cause the fuel tank is metal and rusts alot....
PostPosted: Sat Aug 02, 2003 10:23 pm
Drummer is right. It helps protect the fuel pump. You might want to put one back in.
PostPosted: Sun Aug 03, 2003 11:41 pm
Stock they only have one filter back by the tank just ahead of the fuel pump. If there is a filter under the hood somebody added it later. (Not a bad idea actually) There is a strainer screen in the fitting that hooks to the top of the carb though, and that can get clogged up as well.
The filter really does need to be inline before the pump. The stock pump is pretty sensitive to just about everything from junk going through it to just changes in gas contents. (Methanol additives they put in gas around here always seem to take mine out) Once you've changed it a couple of times you get pretty good at swapping the one back by the tank. Its not that hard to reach, especially compared to pulling the fuel pump out to replace it. ;)
PostPosted: Sun Aug 03, 2003 11:49 pm
Every factory Luv truck i've seen had a filter mounted on a bracket somewere on one of the inner fenderwells of the truck. My 75 had one on the drivers side fenderwell just below the fuse block.
PostPosted: Sun Aug 03, 2003 11:54 pm
well i dont know my 75 and my dads 74 has it like J said but my 80 doesnt have one nor does my dads 82 4wd 8O
PostPosted: Mon Aug 04, 2003 2:32 am
Well I've got ten and have had two others. The only one of the bunch with a filter under the hood was an obvious spliced in job, though they did use the filter with the right number on it. I think what happens to a lot of trucks is people without a book go to swap the filter, can't find it, so they stick it just before the carb assuming there wasn't one.
The only thing I don't have many of are 75 and older trucks. Last complete running one I had around left many many years ago. Might be some of those, especially the older ones (never have had older than a 75) might have a little different set up for the filter. That must be the explanation for our difference of opinion. I have almost all 76 and newer trucks, and have never seen a factory bracket for a filter anywhere forward of the fuel pump. I worked on one of those old 75 motors once and decided that was enough for me, never touch the stuff since. ;) Besides, that skinny little bumper and curb catcher valance look pretty silly to me. :P
PostPosted: Mon Aug 04, 2003 4:37 am
:lol: :lol: i did that. i caught it the next day though. :lol:
Users browsing this forum: Baidu [Spider], Google [Bot] and 86 guests
