It is currently Fri Dec 19, 2025 10:13 am
PostPosted: Sun Feb 01, 2009 2:06 am
I want to pass along a situation I just ran into.
My radio and wipers were not working and that turned out to be a fuse box issue. The fuses were not blown, but messing around/ cleaning them solved the problem.
However, that messing around resulted in my generator light going on.
It seemed to be a fuse box issue but no amount of messing/ cleaning made any difference.
When I pulled the connectors from the back and clipped them together with test wires the generator light would go out.
Confirmation that the issue was with the fuses/ fuse box.
It turned out that the problem was in between the brass plates that are riveted together between the connectors on the back of the fuse box.
I drilled out the rivets, carefully clean all the brass parts, and riveted it back together with some 1/8 copper pop rivets that I just happened to have.
Wallahhh!!! The generator light is now off. Enough oxidation had build up over 29 years that the circuit was incomplete.
Had that light come on when I did not happen to be messing with the fuse box would have meant all sorts of incorrect guesses about what the problem was. I'm sure I would have started with the alternator and moved on to the regulator and so on down the line.
Hope this will help someone else.
By the way, I am the original owner of an 80 2x4 Mikado that I have now had for 29 years and I am just now taking advantage of all the wisdom here.
PostPosted: Sun Feb 01, 2009 5:59 pm
welcome to the site and hope to hear alot more from you. everyone here probably wishes they were the original owners of their luvs. lol thanks for the great info
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Sun Feb 01, 2009 10:34 pm
can you only imagine if everyone was the original owner? no more second hand second guessing, or getting lost in a black tape frenzy from hell!
Juice
PostPosted: Wed Mar 25, 2009 12:46 am
I do believe you may have helped me out with the same issue>..<
80 luv, 89 5spd, 81 ignition, weber 32/36 its a labor of luv
