It is currently Tue May 26, 2026 12:10 am
 Post subject: Body Bushings
PostPosted: Sat Mar 21, 2009 3:45 pm
LSX LUV Owner
Does anyone know where to get new body bushings?
or is there a certain vehicle people use instead for bushings?
thanks
 Post subject: Re: Body Bushings
PostPosted: Mon Mar 23, 2009 12:24 pm
LSX LUV Owner
no one knows anything about body bushings??
PostPosted: Mon Mar 23, 2009 10:20 pm
an old timer said he used rubber hockey pucks and just drilled a center hole in them... just a thought
PostPosted: Tue Mar 24, 2009 12:59 am
I vaguely remember something about early Camaro, Firebird front subframe isolators being close and can be modified to fit.
PostPosted: Tue Mar 24, 2009 9:37 am
I had a machine shop build me some aluminum ones.
PostPosted: Tue Mar 24, 2009 11:05 am
LSX LUV Owner
yeah i ended up having my dad make me some out of nylon. dont remember if the 2 for the front clip were supposed to be taller? but i had him make all 6 same size. everything lines up good.
PostPosted: Mon May 04, 2009 7:10 pm
do you have the dimensions foro the bushings you made
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Mon May 04, 2009 8:45 pm
Rubber ones isolate noise and vibration. Well that is what they were supposed to do. Any hard mount will not do that. Not that it matters that much I think.
PostPosted: Tue May 05, 2009 8:33 pm
What about old urethane roller skate wheels? Not the in-line wheels, but the old school style skates with trucks.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue May 05, 2009 11:15 pm
Try this http://www.metrommp.com/
Left side links, 2nd one down "Universal parts", then look under "Body cushions". They have lots of them. You will want to measure your stock ones. Maybe they have a direct fit or you might have to trim a little.
Either way you can keep the rubber ones of you want. Post your findings for us if they have something that works.
DB
