It is currently Tue Dec 23, 2025 8:01 pm
 Post subject: im haveing carb issues
PostPosted: Fri Mar 13, 2009 12:56 am
i have a 32/36 carb. the problem is my idle is about 2k cold and my screw is all the way out 8O if i lean it out it will run like crap when its warm. any sugestions i was told air leak so i just put new gaskets all around from carb to head
PostPosted: Fri Mar 13, 2009 9:36 am
here check this out ...
http://www.webercarburetors.com/ppw/htm ... _best_.htm
but this is your problem would be my guess...sence you have new gaskest and should have no vacuum leak
Simple Rules for low speed calibration
If the mixture screw is more than 21/2 turns out turns then the Idle jet is too lean (too Small). When the mixture screw is less than 11/2 then the Idle jet is too rich (too large). These assumptions are based on the fact that the speed screw setting is not opened more than 11/2 turns. If the speed screw has to be opened 2 or more turns then this is also an indication of a lean condition usually requiring greater change. At times it may appear to be showing signs of richness or flooding it is really a lean condition. See pictures and notes in the tech 2 article supplied in the kit instructions, view and please understand the need to keep throttle plate as near to closed as possible so as not to prematurely expose the transition holes. This is what causes the visible rich condition, and confirms the need to increase the jet size. JET KITS are available if needed.
PostPosted: Fri Mar 13, 2009 1:42 pm
i was messing with my carb today and thought id check the mix screw... 4 and about 1/4 turns out. if i lean it out any it misses and runs just like crap. im thinking its the jets now? cuz inorder to get it to run when the mix screw is out 2 turns u have to turn the idle screw in like 6 turns
PostPosted: Fri Mar 13, 2009 4:18 pm
what size jets are in it
PostPosted: Fri Mar 13, 2009 9:19 pm
iidk i cant see them very well looks like big one says 70 and little one says 100 idk
PostPosted: Fri Mar 13, 2009 10:59 pm
here is what i am running
Primary
170 air corrector
F50 emulsion
140 main
50 idle
26 ventury
Secondary
160 air corrector
F50 emulsion
140 main
55 idle
27 ventury
Both with a 50 pumpjet
PostPosted: Sat Mar 14, 2009 12:33 am
it drives but will NOT idle its either way to low idle or about 1500 idle i think im going to rebuild it and try again
PostPosted: Mon Mar 16, 2009 8:05 pm
I wouldn't rebuild or re-jet it just yet. First, make sure your smog equipment and lines are entirely removed and all holes/ports capped or plugged. The EGR valve is a piece of crap and will mess up the Weber performace. The only vacuum lines not capped or removed on my engine are the vacuum advance, the little one between the intake manifold and the valve cover, and the one going back to the gas tank. Getting rid of that stuff completely changed how the truck ran. I put a breather cover on the pcv port on top of the valve cover rather than hooking it up to the air cleaner... either way works though.
Go through the rest of your engine and I'm sure you will find some issues. Check the compression- should be between 120 and 185 with no more than 10% variance between cylinders. Make sure no major exhaust leaks or clogs, new plugs, wires, cap, rotor. Set your valve clearances. Then I would take off the air filter and set the choke. Sounds like that is off. At that point, if you can get it to idle, set the vacuum advance to 12-16 degrees depending on how it sounds. Stock is around 6, I believe, but that's not gonna work for the Weber. That is the short version.... there are some really good sites that will help you out as well.
I just put a brand new 32/36 DGEV on and after doing all that stuff and more, it passed emissions in Oregon and I got tags. Still needs a little tweaking, but it's way better than the Hitachi!
PostPosted: Tue Mar 17, 2009 1:37 am
lol EGR why did i not realize that its still there when i had my 1.8 it has a piece of steel where the egr went. ha geez i cant believe i missed that.
Users browsing this forum: Bing [Bot] and 22 guests
