It is currently Tue Jun 16, 2026 1:08 am
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Mon Mar 09, 2009 11:26 pm
Good idea... 8)
PostPosted: Tue Mar 10, 2009 11:52 am
:signiagree
PostPosted: Tue Mar 10, 2009 9:05 pm
LSX LUV Owner
got the frame welded up....
PostPosted: Tue Mar 10, 2009 9:33 pm
Lookin good! 8)
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Mar 10, 2009 9:36 pm
I second that!! :D
PostPosted: Wed Mar 11, 2009 9:23 pm
LSX LUV Owner
thanks guys.
i got the body mounts welded back on.
PostPosted: Wed Mar 11, 2009 9:29 pm
Man, you are smokin' right along!! Looks like some nice welds there also!! Keep up the awesome work. :D
PostPosted: Wed Mar 11, 2009 9:31 pm
LSX LUV Owner
thanks!
i think tomorrow im going to cut off the old strut rod brackets, and cut out that front crossmember piece. and weld in a piece of 2x2 lower so i can fit a bigger radiator
or sit the motor n tranny back in and throw cab on and get motor mounts n tranny crossmember done.
PostPosted: Wed Mar 11, 2009 10:03 pm
man them are some purty weld there :esmile :ewink
PostPosted: Thu Mar 12, 2009 8:10 pm
LSX LUV Owner
didnt get much done today. i started welding in a new front crossmember. still need to plate part of it and finish welding it up..
also beat the firewall in some. going to cut part of the tranny tunnel out tomorrow so the front of the motor can come up.
PostPosted: Thu Mar 12, 2009 9:28 pm
:smt023
PostPosted: Fri Mar 13, 2009 10:43 pm
LSX LUV Owner
started on the motor mounts. gonna wait till cab n motor/tranny are back out and flip frame over to do bottom side of mounts. tomorrow the cab is coming back off and going to make the tranny cross member.
PostPosted: Sat Mar 14, 2009 1:43 am
great work!
SALINASRACING.COM
PostPosted: Sat Mar 14, 2009 4:52 pm
LSX LUV Owner
thanks demon
tranny cross member..
PostPosted: Sat Mar 14, 2009 8:43 pm
looks good!!!!
PostPosted: Sat Mar 14, 2009 11:03 pm
LSX LUV Owner
thanks!
couple pics cause i thought i needed to snap 2 lol
PostPosted: Mon Mar 16, 2009 5:14 pm
Word of advice....ditch the plastic intake manifold. Those things warp and leak over time, plus they don't look nearly as cool as an aluminum intake 8)
PostPosted: Mon Mar 16, 2009 8:11 pm
LSX LUV Owner
everyone i know has the nylon intakes.. i think ill be fine with it.
thanks for the advice though.
PostPosted: Tue Mar 17, 2009 7:37 am
I would gusset those engine mounts... constant twisting torque may loosen the welds. I could be wrong but I have seen more elaborate mounts break over time.
The good ol days...when parts were plentiful and you could turn heads with a $50 dollar truck.....
PostPosted: Sun Mar 22, 2009 1:53 pm
LSX LUV Owner
gots mah 9"
even though some of the info doesnt matter i looked it up anyways.. out of a 74 F150 made in July(5th week) 3.25 non posi 31 Spline Big Bearing
Users browsing this forum: Baidu [Spider] and 23 guests
