It is currently Wed Feb 04, 2026 8:31 am
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Tue Mar 03, 2009 10:08 pm
LSX LUV Owner
dad cut out the adapter plates for me but no time to drill them. so i drilled them at work. waiting on metric bolts to come in..
cut off pass. rocker. NEW one will be here thrusday so i will proceed with it then...
ground down welds on driver rocker..
PostPosted: Tue Mar 03, 2009 10:11 pm
LSX LUV Owner
also getting z06 cam, push rods, springs, ls6 intake, timing chain set, oil pump, pulleys for 500.. all only has 6K miles on them!
and my friends friend is giving me a stock fbody throttle body my dad is going to mod.
PostPosted: Tue Mar 03, 2009 10:56 pm
Coming along very nicely. Looks like your truck came from Iowa with the rust!! :D
PostPosted: Tue Mar 03, 2009 11:17 pm
so that adapter is 4 the motor mounts
75-luv mikado-V8 350 soon
PostPosted: Wed Mar 04, 2009 2:14 am
Do the plate put the engine mount in the same place as the earlier SB chevy blocks. The bolt in adapters come forward, looks to be close the the position you have now fore and aft. I have'nt seen the newer blocks, to to see where they moved the motor mount location. Also in relation to the crank center line.
WWW.photobucket.com/v8luv
PostPosted: Wed Mar 04, 2009 9:37 pm
LSX LUV Owner
rob, id have to measure against an sbc.. not sure.
heres the ls6 intake and my throttle body bolted up... looking like im gonna have to either push motor back to run a radiator, condenser and efan(s), or sacrifice something. id like to just push the motor back some to simplify everything, but then i dont cause i dont usually like the look of cut firewalls... we will see!
new rocker
intake
hubs made it home!
PostPosted: Wed Mar 04, 2009 10:01 pm
Those hubs look really awesome!!!
PostPosted: Wed Mar 04, 2009 10:09 pm
LSX LUV Owner
yes i cant wait to buy my front wheels and see how much the tuck up in the truck..
PostPosted: Sun Mar 08, 2009 8:24 am
LSX LUV Owner
got the cab off last night. going to widen the front part of the frame so it will clear my longtubes. i will like this way better so if i want to upgrade to a better set of headers/coated ones they will drop in no problems.
buddy in the way lol
putting the cab in the shed today
pacesetters
PostPosted: Sun Mar 08, 2009 6:41 pm
If you don't need too much, you can recontour the firewall. use a 5 lb hammer and care fully plan your strokes. The with a body hammer and dollies clean it up. You could gain up to 2 inches and once it's together, you won't notice. Usually takes up less room inside than cutting.
PostPosted: Sun Mar 08, 2009 8:04 pm
LSX LUV Owner
got some more work done today with the help from a friend...
got the motor n tranny out..
then we got the bed off.. lets in a nice amount of light. i really like it.
made a little wood cart with some casters, rolled cab out to shed
work smart not hard:haha:
rolled out to clean and take a little break
back at it...
how we ended for the day...
so all together, we got the motor/tranny out, bought wood, built cart, bed cleaned out, bed off, gas tank out, shocks off, most little bracketry cut off that isnt going to be needed, frame half ass cleaned up in the spot we are widening it... probably a few other little things but whatever.
tomorrow im gonna do alot of measurements etc and cut off the front 2 body mounts. and hopefully get the frame widened...
PostPosted: Sun Mar 08, 2009 8:07 pm
LSX LUV Owner
im going to have to look into doing something like that maybe..
PostPosted: Sun Mar 08, 2009 8:09 pm
Dam!! Do you not have to work or are you just extremly motivated??? :ewink
You are haulin @ss on that truck! Keep up the good work.
PostPosted: Sun Mar 08, 2009 8:10 pm
8O Man you really went to town today on your truck. That little blue car in the corner is neat!!
PostPosted: Sun Mar 08, 2009 8:29 pm
LSX LUV Owner
i guess extremely motivated lol. i work monday-friday 8-5..
yeah thats my dads car...
PostPosted: Sun Mar 08, 2009 8:50 pm
Sweet!!! :D
PostPosted: Sun Mar 08, 2009 8:55 pm
Holy crap you've covered alot of ground there. I just want to get mine finished as a stock vehicle. Can't wait to see the completed project.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Mon Mar 09, 2009 7:29 am
Have you looked at the 81-82 luv chassis as they are wider in the front section but from the looks of them they are the same cab mount width they look like a perfect fit for a project like yours.
PostPosted: Mon Mar 09, 2009 8:37 am
LSX LUV Owner
Sweet. But that would require me to find another chassis. We can widen mine for free.
PostPosted: Mon Mar 09, 2009 9:48 pm
LSX LUV Owner
me and dad got the frame widened. obviously needs to finish welding it. im going to get started on that tomorrow after work. but headers clear awesomely now! im very happy.
body mount welded together so spacing will be right. and measurement to know how far up the frame
widened with motor set back in to check fitment.
