It is currently Mon May 11, 2026 11:55 am
 Post subject: shift kits
PostPosted: Fri Mar 06, 2009 12:28 pm
what would be the best kit for a turbo 350 trans its in my 80 c-10 and i want it to shift harder than it dose .
DITCH DIGGER 16550
 Post subject: Re: shift kits
PostPosted: Fri Mar 06, 2009 7:06 pm
I put the B&M shift improver kit, and used the street and strip stage in my turo 350. When in drive it shifts a little harder, but is not abusive to the rear end. But when you shift from 1st to 2nd and into drive it will churp the tires with no effort. The shifts are hard and fast when you upshift. I really like how it works now. :) :)
PostPosted: Sat Mar 07, 2009 10:53 am
I use TCI kits and have had good luck with them.
