It is currently Sat Feb 07, 2026 7:48 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: 75 pro street
PostPosted: Mon Mar 02, 2009 8:38 pm
this build is gona be really slow speaking i have two luvs im gona try to do at once. im gona restore my 77 speaking in cail they have to pass smog and my 75 is gona be pro street and this post is about the 75. ill get picks up when i can . but here is what i plan to do but u guys imput is always apricited to help me out speking this is gona be my 1st build let alone a pro street truck.
engine: 305
trans : tb400 /tb350
rearend : idk what is good to put in there
turbo: help here too
headers: headmans
the truck is a fleetside mikado which im gona have to get tubed and i am also gona have to put a roll cage in it and have 2 raceing seats with 5 point harness's
the color im thinking chevy orange with black racing stripes
anyone in so cal know a good machine shop to machine my block for me ?? for a good price
75-luv mikado-V8 350 soon
 Post subject: Re: 75 pro street
PostPosted: Mon Mar 02, 2009 9:49 pm
Sounds like you will be busy for awhile. But also sounds like it will be alot of fun. Good luck with your builds.
PostPosted: Mon Mar 02, 2009 10:48 pm
what part of so cal are you from?
SALINASRACING.COM
PostPosted: Mon Mar 02, 2009 10:57 pm
20 miles outa la
PostPosted: Tue Mar 03, 2009 9:23 am
What are your exact plans for your truck will dictate the proper way to build it.
If you are wanting to turbo the motor things are a whole lot different then if you want to go naturally aspirated.If it is a driver and to be a little different look at the 305 TPI (works with turbo as well) with a 700R4 which will give you the best of both as in great take off(3.06 first gear) and the overdrive with the lock up but this is just one little idea and it is your truck but i do like that you are looking for info to compile and then make a decision.As for the rear end that is up to your intended purpose of the truck.Just a clue i built a 82 S10 with a 305 stock other than a marine cam 700R4 and it averaged 32 mpg on the highway.More later if you want.
PostPosted: Thu Mar 05, 2009 7:59 pm
i should be getting the motor and trans soon 305sbc and a 700r4 (temp trans)
PostPosted: Sat Mar 28, 2009 8:52 pm
ok got the 305 today and the 700r4 but the toqure conv. is bad but im not planning o useing the 700r4 anyways i took off the intake on the 305 and put a eledlebrock preforemer and a junk carter afb 4bl to see what it would look like it looks like it belongs in a mikado luv =) next sat i should be getting a 350sbc ad a turb350trans which im gona marry to the 305 and all ill need to do next is get the mounts and a driveline and be good to go with a v8 curiser to putt around in and while im gona be doing that get the 350 built to pro-street hp levels so when i get my truck ready for the second change over ill have that part done
PostPosted: Sun Mar 29, 2009 12:34 am
i was screwing around on summit and bookmarked the motor mounts and the headers the mounts i will get after i sell 1 of my rifles to cover the price of the mounts speaking its gona be cheaper now to go fast than to go shoot some rounds off....
PostPosted: Sat Apr 04, 2009 9:28 am
tear down starts today and hopefully ill be able to buy the motor mounts from summit this week
PostPosted: Mon Apr 06, 2009 12:45 am
day 1
took the fenders off and the grille and the doors
pulled the motor out and raditor
cab on the ground(my friend thinking about what to do next)
350 and g180 motors
took bed off and rolled frame outside
got bored and took some pics of my 77
put motor and trans on frame to see what was what with new "motor mounts"(2x4s but switched to 1x4s more like mounts)
day 2
raised cab to put on frame
350 in truck to see if fits without trans
PostPosted: Tue Apr 07, 2009 6:29 pm
a simple fast and easy motor swap turned into a full blown restoration....
PostPosted: Tue Apr 07, 2009 8:21 pm
so what you doin with the 700 tranny?
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Wed Apr 08, 2009 10:01 pm
its siting out in the shed in my back yard with the g180 and trans idk if the 700r is any good?
PostPosted: Fri Apr 10, 2009 7:57 pm
getting rdy to paint the motor compart primer black than gloss black after the fire wall modding is done
PostPosted: Tue Jul 07, 2009 6:57 pm
im just gona focus on geting the freaking 350 put in the truck and get it running than ill go from there i got in over my head and now i get to climb puta the luv hole lol :lol:
PostPosted: Tue Jul 07, 2009 7:31 pm
If this is your 1st build i suggest one truck at a time....
PostPosted: Tue Jul 07, 2009 7:55 pm
the 77 is my daily i just keep that old girl running my focus is on getting the 350 in my 75 asap lol
PostPosted: Wed Jul 08, 2009 4:34 am
13b periphial port with a 51mm weber carb.over 200hp atw.it will bolt straight in.you wont need to cut anything.and you can be differant!!!
PostPosted: Wed Jul 08, 2009 10:30 am
What are you doing on the rear. Tire size?? Ladder bars,4 link or leafs?
PostPosted: Wed Jul 08, 2009 3:59 pm
how is the cab being supported while its on the engine crane?
