It is currently Sun Jun 28, 2026 7:33 pm
 Post subject: Gas gauge issues
PostPosted: Thu Feb 26, 2009 6:13 pm
My gas gauge never reaches full; more like 3/4. I figure it's either the gauge or the tank sender. Anybody have this problem? Is either adjustable?
Thanks
 Post subject: Re: Gas gauge issues
PostPosted: Thu Feb 26, 2009 6:36 pm
yes it is. you will need to remove the unit and adjust the float.
PostPosted: Thu Feb 26, 2009 7:27 pm
Before you go tearing into your gas tank: Does your temperature gauge read correctly? If your temp is also reading low, I would bet the problem is the instrument panel voltage regulator. If you look at the circuit diagram, you'll see that if you don't have a full 8 volts I believe it is then both your gauges will read low. Both the gauges on my truck read low, and I'm just living with it for now but in the future I will either adjust the stock voltage regulator or put in a solid state regulator. (There's a waveform that those bimetal regulators produce, it's not actually DC, so that might take some doing to get around to replace it with solid state).
PostPosted: Thu Feb 26, 2009 7:37 pm
Yea mine always reads 1/4 tank I just fill up every day
currently working on my 1977 luv truk
PostPosted: Fri Feb 27, 2009 12:29 am
The gauge regulator is just a relay looking thing that plugs into the back of the instrument panel circuit board. Usually easy to replace. Of course finding the correct replacement may be more difficult.
PostPosted: Sat Feb 28, 2009 9:08 pm
my gas gague doesnt even work
75-luv mikado-V8 350 soon
Users browsing this forum: No registered users and 89 guests
