It is currently Fri Mar 20, 2026 7:15 pm
PostPosted: Mon Feb 23, 2009 2:34 pm
my engine ran fine when it was parked it sat for a week now will only run on 3cylinders. new spark plug its gettting spark has compression all are same for the 4 cylinders. cam looks ok valves not out of adjustment. and still will not run on all 4 any ideas?
PostPosted: Tue Feb 24, 2009 8:43 pm
tryt getting a new cap and rotor there cheap so if that's not it your not gunna loose that much but I would try that
currently working on my 1977 luv truk
PostPosted: Tue Feb 24, 2009 8:48 pm
Sorry didn't read it right but I would think a bad plug that's not firing under compresion . What color is the spark? Is it bright. Or weak?
PostPosted: Tue Feb 24, 2009 9:00 pm
bright blue. the only thing i can figure is somthign is plugging my intake manafold
PostPosted: Tue Feb 24, 2009 10:18 pm
Then I would check the intake valve to see if its opening enough I wouldn't think any thing would be blocking the intake manifold unless you dropped something down it
PostPosted: Sun Mar 01, 2009 10:23 am
Check for vac. leaks with some carb cleaner and don't forget the EGR valve where i suspect i have a problem with mine running on 3 cyl's until warmed up then runs on all four.
PostPosted: Sun Mar 01, 2009 3:46 pm
i still have not figured out whats wrong, im putting in a g200 instead. but i hat do use my flywheel and clutch cuz the one on the 200 was bad
