It is currently Thu Jul 02, 2026 8:24 am
 Post subject: how about mopar power?
PostPosted: Thu Dec 04, 2008 9:28 am
i just happen to have a 80's 318 sittin around my yard and wondered if anyone has attempted to install one of these i a luv
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Feb 21, 2009 1:44 am
Not in a LUV, however I have installed a 340 6 pack, modified 904 and narrowed 8 3/4" rear end, into a 1971 Datsun without cutting the firewall.
PostPosted: Sun Feb 22, 2009 7:05 pm
there is a 74 luv plow truck on craigslist with a dodge 360 in it
PostPosted: Mon Feb 23, 2009 3:01 am
Problem is that the dodge 318, 340, 360's are about 125lbs heavier and almost 3" longer on installed length with the shortest water pump. Dimple the firewall back for dist clearance, You also will need to get a rear sump pan and pickup, look at the trucks and early vans.
