It is currently Sun Jun 28, 2026 3:58 pm
PostPosted: Sat Feb 21, 2009 1:13 am
I'm going to put in a CD player. THe wiring is pretty straightfoward from the diagram on the back of the cd player. However I'm not sure what wire to use off the wireness as the power wire.
PostPosted: Sat Feb 21, 2009 6:55 pm
It looks like the original power to the radio was a lavender colored wire. However, check with a volmeter or test light, key on or accessory position.
PostPosted: Sat Feb 21, 2009 7:22 pm
The original will work for the "ignition on" circuit, but you will need to find a fused "always hot" wire for the stereo to keep the clock and presets saved. You can find an already fused hot wire, or just a hot wire from something else, and install your own in line fuse.
PostPosted: Sat Feb 21, 2009 7:23 pm
I ran my secondary directly to the battery with a fusible link.
PostPosted: Sat Feb 21, 2009 10:44 pm
The first wire tha comes to mine that is always hot, is off the headlight switch.
NLUV suggested using the hot wire off the ignition switch.
PostPosted: Sat Feb 21, 2009 11:58 pm
I think I went off the ignition on one of mine, and my son and pals did the 78 and went to the battery.
PostPosted: Sun Feb 22, 2009 2:34 am
Whats the wattage of the deck?? I always run the power straight to the battery with a fuse.
PostPosted: Sun Feb 22, 2009 11:02 am
I bought it used, so I dont know the wattage. There is a 15amp fuse on the back of the deck.
PostPosted: Wed Feb 25, 2009 8:45 pm
It's probably 50x4 or something like that. Which means it probably does 20 watts rms per. If you do a search for the model number, you can probably find all the specs on it.
Cam
