It is currently Tue May 26, 2026 6:49 am
 Post subject: air ride and v8
PostPosted: Wed Feb 18, 2009 10:00 am
 Post subject: Re: air ride and v8
PostPosted: Wed Feb 18, 2009 10:04 am
PostPosted: Wed Feb 18, 2009 10:05 am
PostPosted: Wed Feb 18, 2009 10:06 am
PostPosted: Wed Feb 18, 2009 10:07 am
PostPosted: Wed Feb 18, 2009 10:08 am
PostPosted: Wed Feb 18, 2009 10:09 am
PostPosted: Wed Feb 18, 2009 12:21 pm
LSX LUV Owner
Lookin good. I need to start doing rust repair.
PostPosted: Wed Feb 18, 2009 6:09 pm
looks good man :smt023
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Wed Feb 18, 2009 7:59 pm
lookin' good.
PostPosted: Tue Feb 24, 2009 5:56 pm
hey any suggestions cab off or not
PostPosted: Tue Feb 24, 2009 6:12 pm
I would remove the cab if you are going to do air ride and a V8. The Trans crossmember hangs below the frame and your going to have to make a new one anyways since you cant run the exhaust under the crossmembers if you want to lay frame. It could all be done with the cab on but once you get under there and start doin it youll wish you would have pulled it.
Also gives you the chance to paint the frame and undercoat or paint the bottom of the cab. :)
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Feb 24, 2009 6:15 pm
:signiagree
PostPosted: Thu Feb 26, 2009 10:31 pm
getting some floor pans out of an olds that is cut up in my back yard hopefuly it will be a little easyer than just bending around some sheet metal
Users browsing this forum: No registered users and 73 guests
