It is currently Sun Jun 28, 2026 1:51 am
Post new topic Reply to topic  [ 246 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12, 13  Next
 Post subject: Re: truck pic's
PostPosted: Sat Feb 07, 2009 8:05 pm
Got these as part of the vacuum pump install. I sure did hate to weld on my shiny new parts...
PostPosted: Sat Feb 07, 2009 8:25 pm
Nice!!!! Too bad they aren't for a BBC, I would have to take them off your hands!!! :D
PostPosted: Sat Feb 07, 2009 8:33 pm
They are very nice for the price. $82.45 shipped to my door. Fit and finish are way better than I was expecting...The weld bungs were just under $20.00 shipped...
PostPosted: Sat Feb 07, 2009 8:48 pm
That is cheap. Where did you get them?
PostPosted: Sat Feb 07, 2009 10:53 pm
Here is a link to the big un's from the feebay site I got mine from...
http://cgi.ebay.com/ebaymotors/Big-Bloc ... 0275350285
Shipping should be pretty quick to you... :lol:
PostPosted: Sun Feb 08, 2009 8:02 am
Thanks, I'll check it out.
PostPosted: Mon Feb 09, 2009 6:25 pm
Getting crowded up front...
PostPosted: Mon Feb 09, 2009 8:44 pm
Lookin' good. But it would of looked better on my truck!! :D The place where you got your valve covers from is only about an hour from me. A guy I know sells parts in Hudson. Will have to see if that is him.
PostPosted: Sun Feb 15, 2009 7:12 pm
Well, progress has been made. I got my other valve cover on, ( the one under the 6 solenoids, :D ). I also finished fabbing and installing my gauge panel for the voltmeter and the vacuum gauge, what a PITA, but it's done. Also, (hopefully) I have my alternator charging, and more importantly, shutting off when I try to...What I still need to do is wire in the lights for the gauges, and I need 1 12 AN fitting and I am waiting for 1 hose to come in. Then it's time to fire it up and check for leaks, and then a bath for it. If the weather cooperates, next weekend is time for the first pass of the year...
PostPosted: Sun Feb 15, 2009 7:22 pm
You will have to post some pics. And let us know how things go next weekend. Good luck and hope the weather is good for you.
PostPosted: Thu Feb 19, 2009 5:18 am
:smt097 Smiley says it all. Finished up everything and tried to start it to check everything, and no start. Finally, when it's too late to do anything about it, I discovered the fuel I overpaid for is bad. The truck would turn over and occasionally fire randomly. Sounded like a timing issue. After chasing connections and triplechecking everything off and on for 2 days, I dribbled a little gas for the generator in the carb and it fired right up, until that fuel was expended. And to top it off, the forecast is too cold for my liking for Sunday...
PostPosted: Thu Feb 19, 2009 6:15 am
that sucks real bad.
PostPosted: Thu Feb 19, 2009 6:29 am
that sux...do all that work chase everything down and find out it something simple, but isn't that the way it usually goes.aleast it wasn't something major as far as electronics....maybe this will help you until you can drive it.
last summer
PostPosted: Thu Feb 19, 2009 9:52 am
PostPosted: Thu Feb 19, 2009 12:50 pm
:signiagree
PostPosted: Thu Feb 19, 2009 9:36 pm
You guys knock it off or I'll be buying Karl's truck and putting a cage in it to go do some of that. I'm starting to get the itch. Maybe I'll build one.
PostPosted: Thu Feb 19, 2009 9:49 pm
WARNING!! Once you start do it, you can't stop, no matter how hard you try. Believe me , I am living proof!! :D
PostPosted: Fri Feb 20, 2009 5:21 am
amen brother!
PostPosted: Mon Feb 23, 2009 11:40 am
PostPosted: Tue Feb 24, 2009 9:08 am
Ya, its a sickness with no cure.....although lack of money can slow its progress
Users browsing this forum: Baidu [Spider], Bing [Bot] and 65 guests
