It is currently Mon Mar 23, 2026 8:20 pm
PostPosted: Fri Jan 30, 2009 11:33 pm
thought this might be interesting :D
PostPosted: Sat Jan 31, 2009 9:46 am
My truck has a .030 over 454 with LS7 Rectangle port cast heads. Here are some specs.
Balanced 460 BBC
Stainless Steel Valves
System 1 Oil System
Crane #138291 Roller Cam
Triple Crane Springs
Crane Roller Lifters
Crower Roller Rockers
J & E Pistons
Cam Chain Drive
CSR electric water pump
CSR thermostat housing
Moroso Valve Covers
Champ Oil Pan and Pickup Tube
Speed Pro Plasma Moly Rings
SFI Certified Flex Plate
Crane Valve Stabilizer
Eagle Rods
ATI Damper
PostPosted: Sat Jan 31, 2009 10:47 am
Black & Decker aquarium pump...
PostPosted: Sat Jan 31, 2009 11:27 am
:lol: :lol:
PostPosted: Sat Jan 31, 2009 3:05 pm
455Buick/4spd.
PostPosted: Sat Jan 31, 2009 6:14 pm
My 74
406 CI SBC/350 trans
The 76
4.3 Vortec/2004R trans
PostPosted: Sat Jan 31, 2009 8:37 pm
2 hungry squirrels on a treadmill, backup hand wind rubber band w/nylon drive gears.
PostPosted: Sun Feb 01, 2009 12:30 am
I always get the #2 combo large size!!! :smt016
PostPosted: Sun Feb 08, 2009 7:59 pm
i have the 180 of a rice rig.
a bean rig.
diesel that is :lol: :lol:
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Sun Feb 08, 2009 9:22 pm
1978 mikado
2002 lq4 6.0l 364 ci.
vic jr intake 750 holley
cam/springs/lifter/pushrods
th350 3500 stall
6.0l ls1 swap th350
PostPosted: Wed Feb 11, 2009 2:31 pm
327 / TH350
PostPosted: Fri Feb 13, 2009 10:16 am
well for now it has a 231 buick v6 in it that has had plenty of go fast goodies put in it. dont know much about it cause thats the way i bought it. has an intermittent miss in it tho and i cant figure out what is causing it so out with the headache and in with a 327 and 700r as soon as they get here that is.
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Fri Feb 13, 2009 12:15 pm
Well I pulled the boat motor last fall, but due to the economy I wasn't able to build a 540 like I wanted. I did scrape up enough used part to build a 461. Timing chain, bearings, rings and gaskets are new, the rest is stuff I had laying around, picked up from a buddy or Ebay.
454 BBC bored .030 over
Canfield Alum Heads
Manley 13:1 pistons
Comps solid roller cam 268/274 @.050 with .690 lift
Crower solid roller lifters
Brooks Alum rods
Holley intake with 900 CFM TBI and 85lb injectors running on E85
Not actually running this TBI
PostPosted: Fri Feb 13, 2009 6:51 pm
396 sbc / glide / 9" ford
PostPosted: Sat Feb 14, 2009 9:11 pm
350 block,30 over splayed 4 bolt mains.Speed-pro forged pistons,scat beam rods.Forged crank,crane cam,pete jackson style gear drive.Edlebrock rpm series heads,crane gold rockers.Weind 6-71 supercharger with 2 holley 750s.Turbo 350 with tci 4100 stall.
PostPosted: Sun Feb 15, 2009 10:33 am
No engine questionable TH350 tranny. Thought about a LS1 with a 6 speed tranny.
Some times I amaze even myself!!!!
