It is currently Thu Jul 02, 2026 6:21 pm
 Post subject: G200 Crank
PostPosted: Mon Feb 02, 2009 5:55 am
Are the G200 and G180 have the same crank? Both cranks I have one in a G180 and the other in a G200 need repaired and the G180 is in better shape so it would be cheaper to fix, but I want to use the G200.
2003 F250 7.3L
1975 Luv
 Post subject: Re: G200 Crank
PostPosted: Mon Feb 02, 2009 4:22 pm
Dunno...mine has an electric start. 8)
Time to get a micrometer and check the specs in the manual maybe? :eugeek
PostPosted: Mon Feb 02, 2009 5:03 pm
That took me a second and I have a 39 Chevy! :|
and yes, I am :offtopic
PostPosted: Mon Feb 02, 2009 7:09 pm
that took me a minute to figure that out too...but does any know if the crank shafts from the G180 is the same as the G200? I am back at my place right now, and if I find out they are my father is going to grab the crank from the G180 and go get it fixed, for i can start working on the motor on Friday...or at least soon depending on how long it takes the guy to get to it.
2003 F250 7.3L
1975 Luv
PostPosted: Tue Feb 03, 2009 12:45 am
Only way to tell for sure would be to check and compare the specs in a manual, grab a micrometer, and check them both. I'd check on the specs for ya - but I'm not at home where I can get to my manuals.
Sorry...maybe someone else here can look it up for ya. Good luck on your build.
PostPosted: Tue Feb 03, 2009 5:39 am
It looks like that is what I will have to do, Its just that its not at my place so i can not just do it, and so i was hoping someone had their manual for both motors to check.
2003 F250 7.3L
1975 Luv
PostPosted: Sat Feb 14, 2009 12:07 pm
wikipedia says the g180 and the g200 have same stroke
PostPosted: Sat Feb 14, 2009 2:38 pm
If they are the same stroke and use the same bearings then that just leaves the balance to question as the g200 has a bigger piston hell it should be balanced on rebuild any way but that's how I do things.
