It is currently Sun Jun 28, 2026 4:30 am
PostPosted: Sun Feb 01, 2009 10:50 am
Hey guys, I've been posting mostly in my 'oh crap my truck ain't running' themed topic here: viewtopic.php?f=5&t=18688
Last night I went out and bought a '72 Luv, all one color mind you, with a few issues, but it runs. It was stupid because I really need a driving car and this thing has major issues once you get into 3rd and 4th, but I liked it a lot......... stupid luvs, they are just so darn cute.
So the guy was putting it together for racing at a local track, so the engine and transmission are the strongest he could find (later year 1.8 Izuzu and stock transmission, no idea if they came together). Basically I put a voltage regulator on it and a battery and drove it away. The clutch is pretty funky, gotta let it ALL the way out before it does anything. Everything feels sturdy though, even the doors. And there's no rust in the usual places, just a quarter-shaped hole someone must have punched through the floor. Dash is actually pretty nice for a luv.
I didn't get it home because I couldn't get the thing over 35 and it was really giving me trouble, so I'm going back to where I parked it today to drain the transmission, put some 5w30 in there (that's right, isn't it?). And put oil in the engine, and brake fluid. And I'm going to try and hook up the fuse box right... It's currently just hanging with half the wires attached. To get both headlights last night I had to turn on the high beams and then unplug the only one that was working. If I didn't have the high beams on then I only had one headlight. Basically, the wiring is a mess, but it's a centralized mess. I don't know what year the engine is, I wish I did, because that would really help me find the fuse box wiring, it's not the 72 fuse box. Only half the instrument panel lights up and only half the ignition is hooked up (it only starts and runs, you can't turn it off.) There's no muffler, and the wheels are not held on by the proper amount of lugs, can't give you the exact amount because it's different on every wheel :)
Well... There she is, I'd love any suggestions or comments.
Thanks,
Caleb
PostPosted: Sun Feb 01, 2009 4:23 pm
Hey guys, spent the morning re-doing some stuff and I have a question.
The fuse box needed to be partially rewired and I had everything done and then attached the battery, but when I connected the positive, there would be a clicking noise. I finally figured out where it was, it's a relay on the passenger side that looks like it has something to do with acceleration (according to the 72 wiring diagram on this site). I found the wire in the fuse box that runs over to it. It's solid red and the relay clicks whenever I touch the wire to its proper place on the bottom of the fuse box.
I'm just wondering what it means and what I should do about it.
If you have an answer or idea i'd appreciate it if you could give me a quick call, I'm trying to get it home soon.
- Caleb
541.337.2357
PostPosted: Sun Feb 01, 2009 8:10 pm
Disregard the above post. I can't seem to delete the damn thing... regardless of the browser I'm using, there is no edit or delete button...
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 90 guests
