It is currently Wed Jun 24, 2026 3:43 pm
 Post subject: Broken Transmission
PostPosted: Tue Jan 20, 2009 10:58 pm
Can anyone tell me what transmission tail shaft housings (rear most part of transmission that bolts onto main housing) will work with my 1982 Chevy Luv Diesel 5spd 2wd. I have broken mine and can't seem to locate an exact match. Any Help would be Great
 Post subject: Re: Broken Transmission
PostPosted: Thu Jan 22, 2009 4:01 am
Australian LUV Guru
The gasser Luvs Isuzu Pups and Troopers used the same tranny but with a different bell housing.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Fri Jan 23, 2009 4:27 am
the case on the diesel trooper trans is stronger.
so i dont (think) a case from a trooper will work.
but the guts are the same, go figure.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Mon Jan 26, 2009 9:49 am
You need an '86-'94 5-speed. It doesn't matter if it's from diesel or gas as long as you have the front half (bell housing) from a diesel 5-speed. They used stronger transmissions beginning in '86. Unless you find one from a diesel, your speedometer will be off and will need correction.
