It is currently Mon Jun 08, 2026 7:57 am
PostPosted: Mon Jan 19, 2009 10:24 pm
My heater/vent fan only works on the HIGH setting, on the LOW setting the fan is dead.
Is it the fan, a relay, the switch or could it be something else? I want to fix this before the cold mornings/nights come my way.
Thanx in advance
Dano
Garage is empty;
Between trucks
PostPosted: Wed Jan 21, 2009 12:54 am
Usually a bad resistor block assy. Follow the wires from the heater fan motor to a 2-4 wire plug on the heater housing plugged into resistor assy. Usually remove two screws, remove the thing from the housing and check very closely for an open or broken coil.
PostPosted: Wed Jan 21, 2009 1:34 am
Thanx good place to start troubleshooting.
Garage is empty;
Between trucks
Users browsing this forum: Bing [Bot] and 34 guests
