It is currently Mon Jun 08, 2026 6:43 am
PostPosted: Mon Jan 12, 2009 1:13 am
i have a 1979 chevy luv 4x4 an when i brought it home i relzed the the wheel berrings were grinded to pices. i thoght this was the worst problem.Boy was i wrong turns out the front left hand side spidle were the half shift goes throgh and the wheel bearing rest on had been grinded down from the tire (rim) rubing aginst it. the wheel bearing lock nut was meesed up as wheel. i would luv to have this little truck running agin but i just cant find the parts or how to fix it!! :( the parts that i think i need are - front left spindel (i think thats what there called) wheel bearing lock nut(x2)- and 2 lockers for the front the truck runs fine other then that. If any when could help me find the parts on a budget it i would be very greatfull.
PostPosted: Mon Jan 12, 2009 2:04 am
where are you located? also try this if no one here has what you need
http://www.car-part.com/index.htm
PostPosted: Mon Jan 12, 2009 8:26 pm
am from arkansas close to pinebluff.
Users browsing this forum: Google [Bot] and 58 guests
