It is currently Tue May 26, 2026 5:59 am
 Post subject: turn signal problem....
PostPosted: Fri Jan 09, 2009 12:41 am
I did a search and couldn't find a answer for my problem.
My problem is when I have my driver side blinker on the front won't light up but the back does? In between blinks on the rear it kinda stays dimly lit. All other lights work just as they should.
What I've done to try and fix the problem.
1. Replace bulb.
2. Cleaned inside of housing connections
3. Checked wiring all seems in tact and in good condition
4. Trying the test light now.........
Is there any thing else that could be causing this problem?
PostPosted: Fri Jan 09, 2009 12:55 am
in order for either one to come on(frotn or rear) you have to have a complete circuit. So a you have a small short, or bad connection.Take apart the connection between the switch and turn lamp assembly just inside the core support. Sometimes a little moisture gets in there, hope this helps
PostPosted: Fri Jan 09, 2009 1:16 am
Found the problem I took out the front signal assembly and the turn signal wire broke off in my hand so I need a new light assembly or solder it back together sorry for the pointless post and thanks for the reply NLUV
PostPosted: Fri Jan 09, 2009 8:42 pm
There is no such thing as a bad question but there can be bad advice but since you asked here the advice almost always help.
PostPosted: Tue Jan 13, 2009 12:19 pm
no solution though just wanted to comment: mine has the same problem thouugh its my rear right signal its been two years now and i think it a short in to wire itsself somewhere along my bed. i have tried all of what you've done and i still not working so i just use hand signals :D
Just a young lady who loves cars
PostPosted: Tue Jan 13, 2009 5:16 pm
Assuming you have a good battery this won't help but just in case. I was changing the stock lights with aftermarket and just couldn't get them to work. It was driving me nuts I replaced the flasher and pulled them off and put them back with no luck until I went to start my truck. Sumbitch was deader 'n hell. Once I charged it up and got it started the signals worked just fine.
