It is currently Tue May 26, 2026 9:31 am
PostPosted: Sun Jun 29, 2008 11:45 pm
I need some chassis measurements. I need them off a stock 2wd truck. Thanks
wheelbase
front width (wheel mounting surface on the drum/disc face)
rear width (same as above)
PostPosted: Tue Jul 01, 2008 2:25 am
I thought someone posted the picture up once from the factory workshop manual.
Bob.
PostPosted: Wed Jul 16, 2008 2:47 pm
I did a search before asking and could not find anything.
PostPosted: Wed Jul 16, 2008 3:16 pm
How about this page?
http://www.luvtruck.com/pdf/75luv.pdf
Or this one?
http://www.luvtruck.com/PDF/LUV_Demension.pdf
77 2wd - Back on the road
05 Ford Five Hundred
PostPosted: Thu Jan 01, 2009 1:46 pm
http://www.luvtruck.com/pdf/75luv.pdf" onclick="window.open(this.href);return false;
Or this one?
http://www.luvtruck.com/PDF/LUV_Demension.pdf" onclick="window.open(this.href);return false;
Those help but the width measurements are for track width, that is not always the same as the actual hub to hub measurements. Is there anyone that can get me the actual hub to hub (wheel mounting surface) measurements? Thanks
PostPosted: Fri Jan 02, 2009 10:14 am
54" on a '78, should be the same for '87 & older Isuzu/LUV trucks, Troopers & '88 & newer trucks are 58".
PostPosted: Fri Jan 02, 2009 11:36 am
Is that for the front or rear? Thanks
J Man
PostPosted: Fri Jan 02, 2009 11:02 pm
Nominally both- the rear solid axle is constant, the front varies slightly as the control arms flex but the book list the same dimension for both ends. BTW Toyota p/u solid axles same 54".
PostPosted: Sat Jan 03, 2009 12:30 am
Is this 4wd you are talking about?
PostPosted: Sat Jan 03, 2009 3:12 am
The book I checked was for a 2wd but 4wd's are the same.
PostPosted: Thu Jan 22, 2009 8:46 am
the wheelbase is 102.5 inches from front center to rear center
Users browsing this forum: Baidu [Spider], Google [Bot] and 36 guests
