It is currently Mon Jun 08, 2026 9:08 am
 Post subject: Brake HELP needed
PostPosted: Wed Dec 03, 2008 6:36 pm
ok.. my brakes are weak, close to gone. i changed out the master cylinder with a used one from another luv i had and bleeded the brakes. still the same. i recently purchased a new master cylinder to try to fix the problem. if this doesnt work, what can be the problem.?
 Post subject: Re: Brake HELP needed
PostPosted: Wed Dec 03, 2008 6:44 pm
there is air in the lines, need new fluid, your calipers are mounted upside down/wrong sides, bleeder valve always is on top. Or your rotors are too thin, can be several things
PostPosted: Fri Dec 05, 2008 9:48 pm
You might have a bad brake booster or a vacum leak to the booster. Also check your pads for wear and if they are still good adjust the rear brakes to get some of the slack out of it.
1975 V8 Luv
1980 Bagged Luv
