It is currently Tue Mar 17, 2026 12:37 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: CT'S STEPSIDE
PostPosted: Wed Sep 10, 2008 10:05 am
WildLuvRacing1974 wrote:
Sounds sweet. I likey!!!
Dont tell me you are afraid of a hurricane.
Good luck on the truck and even better luck on the hurricane, be safe and I hope no one has any major problems with it. My parents live in South Flordia so I understand the waiting game.
PostPosted: Wed Sep 10, 2008 5:52 pm
not afraid just want to know if i need to get the old plywood and screws out.... i hate this last minute stuff.
PostPosted: Thu Sep 11, 2008 8:45 pm
good luck at the track.
PostPosted: Tue Oct 07, 2008 6:55 pm
Sweeeeeet! sounds good . lot's of progress .
PostPosted: Fri Nov 14, 2008 6:05 am
Bump for an update .
PostPosted: Fri Nov 14, 2008 6:18 am
here's an update...
thought i had an engine problem turned out to be ok, put the motor back together and now the freaking oil pan has a small leak in the rear seal :evil: :evil: i can't get it to stop dripping for shit!!!!! going to try one more time to get it to stop if it don't gonna put a diaper on it and i'm headed to the nasty ( navasota ) on sunday the 16th to feel out the new truck a little.hoprfully everything will go well and not to many problems sunday.
PostPosted: Fri Nov 14, 2008 3:47 pm
Little River (Temple Academy) Raceway has free racing Saturday the 15th, Food too. Gate is $15
About a 2 hours farther away....
http://www.littleriverdragway.com/boards/index.php/topic,152.new.html#new
Just a heads up...
PostPosted: Fri Nov 14, 2008 3:48 pm
I am glad to see Navasota open back up again.
PostPosted: Fri Nov 21, 2008 12:01 am
bump for an update and full report on the "nasty" trip.
PostPosted: Fri Nov 21, 2008 5:34 am
nasty trip was great....tech'ed in.... getting ready...... i let a little black falcon or comet go ahead of me and the next thing i know he leaves out of shape....goes from the right lane too the left over the guard rail on the left side and threw the wood wall and rolled over 1 or 2 times. 8O it took them about 45 minutes to get it back together.
truck ran like shit! got to figure out the stock shifter and how to shift AGAIN!!!! i only got two passes in 1st one maybe half track..miss shift into NEUTRAL :oops: felt ok, second pass left it in drive and it sounded like a single speed trans and only ran a low 7 but throttle cable was pulling out of the adjuster housing. the oil leak started again it smoked at the end of the last run so i called it a day and watched the others run. there were three other luvs out there a few s-10s overall the nasty had a good turn out for sunday. we have pic's on our web site and i will try to post a link later.
PostPosted: Fri Dec 05, 2008 9:10 am
question on the radiator, did you flatten the bottom tabs, I have the same radiator and I made a mount the puts the radiator in front of the rame about 2 inches below frame level because it looked like the raditor fill cap would hit the hood when closed. and what kind of ;lower pulley did you use? I am using a 2 groove.
Thanks for the great build it looks great
PostPosted: Mon Dec 08, 2008 5:25 am
i did not flaten the bottom tabs but mt tabs are the same height as the front support and i did not have anyproblem with the rad cap hitting the hood, there is more room under the hood than looks i know it fooled me.i'm using a two groove pulley but it is for a short water pump set up, my old long water pump set up would not work on this truck motor was to far forward this time.i will see if i have a picture and post it.
PostPosted: Mon Dec 08, 2008 7:18 am
Thanks, I am running a 2 grove and short water pump also.
Picture would be great.
PostPosted: Sun Dec 14, 2008 11:40 pm
bumping this for an update man .
PostPosted: Mon Dec 15, 2008 5:07 am
lost a lobe on the cam number 7 exhaust, so i'm tearing it down to replace the cam...for now i'm just going to put my old hyd cam in till after the first of the year :evil:
PostPosted: Mon Dec 15, 2008 12:18 pm
Roller!
PostPosted: Mon Dec 15, 2008 12:32 pm
replacement = UPGRADE! (works most of the time with my wife , you know if I HAVE to repalce it might as well an upgrade) a Roller cam is always nice
PostPosted: Mon Dec 15, 2008 12:33 pm
maybe after the holidays....i have to buy OTHER people gifts :x-mas:
PostPosted: Sun Dec 21, 2008 6:17 pm
Remember to put a good word into Santa while you are at it.
PostPosted: Mon Dec 22, 2008 5:37 am
i did put in a good word with santa..... hopefully he/she/me will deliver the 2004 gto with 8575 miles on it this week :D
