It is currently Tue May 26, 2026 6:47 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Nov 28, 2008 9:35 pm
THIS IS MY 300HP/350 GM PERFORMANCE CRATE MOTOR, WITH A 68 T-10 4 SPD. TRANNY AND HURST INLINE V-GATE2 SHIFTER. CAMARO 10 BOLT 4.10 POSI. CUSTOM DASH PANEL.
PostPosted: Fri Nov 28, 2008 10:18 pm
nice
PostPosted: Fri Nov 28, 2008 11:30 pm
that is a nice little truck. looks like it is a quick little ride also.
PostPosted: Fri Nov 28, 2008 11:50 pm
PostPosted: Fri Nov 28, 2008 11:52 pm
THX. IT DOES REALLY FLY.
DRIVER CARRYS NO CASH,EX-WIFE HAS IT ALL!
PostPosted: Sat Nov 29, 2008 11:56 am
I hope you plan on slapping a scoop over that rain catcher of yours. :ebiggrin I like it though.
PostPosted: Sat Nov 29, 2008 3:47 pm
THX,BUT IT DOESN'T GET DRIVEN IN THE RAIN.
PostPosted: Mon Dec 01, 2008 5:21 pm
is that due to too much power and not enough traction in the rain or just by choice
by the way could you get some close ups of the radiator and how its mounted and what size did you use?
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Mon Dec 01, 2008 6:16 pm
ITS A LITTLE BIT OF BOTH,NO TRACTION WHEN ITS WET AND THE TIRES ARE TO BIG AND KICK UP A HELL OF A SPRAY = A TICKET AROUND HERE. THE RADIATOR IS A UNIVERSAL GM 19HX24W WITH A 16" ELECTRIC FAN ON THE FRONT. I WILL POST SOME MOUNTING PICS SHORTLY.
PostPosted: Tue Dec 02, 2008 3:08 pm
Awesome! Its nice to see another 4 speed V8 luv around nothin like slammin gears especially in a luv!
So what gears are you runnin in the rear? Im lookin to upgrade mine I got a T-10 too, but with the stock rear and 25" tall tires I can pretty much start out in 4th lol.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Dec 02, 2008 11:48 pm
THE REAR IS A CAMARO 10 BOLT WITH 4.10 GEARS AND A POSI UNIT. I WANT TO NARROW IT A LITTLE AND BUILD A TRIANGLATED 4 LINK WITH QA1 COILOVERS OUT BACK. THAT SHOULD MAKE ME LAUNCH HARD. WHAT YEAR AND MOTOR IS YOURS?
PostPosted: Wed Dec 03, 2008 10:49 am
mines a '75 with a '77 400 and a super t-10 4 speed the motor has a slight rod knock though, its been like that for about 3 years now. I plan to switch to a 283 soon. Its the blue truck in my sig
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 03, 2008 2:31 pm
When i first built my truck i had a 283 4spd.stock rear stock size tires and i drove it everywhere and it was fun and dependable sometimes i wish i had left it that way as i could drive it more often. Not that my truck isn't fun but now it has no heater, radio,and the wipers are hand use only(fair weather truck).
PostPosted: Wed Dec 03, 2008 2:46 pm
DAN, SORRY ABOUT THE ROD KNOCK,NICE LOOKIN TRUCK. IM GOING TO TRY TO FIGURE OUT HOW TO HOOK UP HEATER HOSES SO I CAN HAVE HEAT AND DEFROST,ANY HELP YOU COULD OFFER? THX. *PAUL
PostPosted: Wed Dec 03, 2008 8:02 pm
Heres a pic of what I did with the heater hoses.... since your motor might be set in your truck differently than mine it may or may not work. They are just 5/8" copper elbows you can get at home depot not sure where the aluminum one came from though, I found it in my garage. Heat works great too with the high flow pump I got. :wink:
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 03, 2008 8:37 pm
THATS A GREAT IDEA,BUT WHICH LINE GOES TO THE PUMP AND WHICH GOES TO THE INTAKE? OR DOES IT MATTER. *PAUL
PostPosted: Wed Dec 03, 2008 8:42 pm
It doesnt matter which way you connect it.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Wed Dec 03, 2008 9:20 pm
GREAT,I JUST WENT OUT AND LOOKED AND THAT WILL WORK PERFECT,THX.AGAIN.
PostPosted: Fri Dec 05, 2008 8:23 pm
DAN, YOU DIDN'T HAPPEN TO HAVE THE STOCK LEAF SPRING SHAKLES? IF HOW MUCH DO YOU WANT. THX. *PAUL
PostPosted: Fri Dec 05, 2008 8:27 pm
If your talking about the ones off of my bagged luv I dont have them anymore I threw them out about a year ago.
1975 V8 Luv
1980 Bagged Luv
Users browsing this forum: Google [Bot] and 50 guests
