It is currently Sun Feb 01, 2026 8:28 pm
 Post subject: 318 IN Dakota?
PostPosted: Tue Dec 02, 2008 11:23 pm
Can anyone tell me if Dodge put a 318 (5.2L) in the Dakota in 2000. Thanks.
Some times I amaze even myself!!!!
 Post subject: Re: 318 IN Dakota?
PostPosted: Tue Dec 02, 2008 11:31 pm
318 and 360
PostPosted: Wed Dec 03, 2008 12:33 am
Thanks do you know if there was a 5 speed that could hook up to it. I am a Chevy guy but I am getting a Dakota from my folks.
PostPosted: Wed Dec 03, 2008 9:21 am
It will fit. My dad and brother both have Dakota's so I've turned a few wrenches on them. I think Dodge was putting 318's in them for a while. Maybe they still are. The 318 will bolt up the the tranny if yours has the big V-6 in it. 4.1L I think is what it is. Essentially a 318 with two cylinders "chopped off". I'm not sure about Radiator clearance or if you'll have to move motor supports on the frame or not. Good luck.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Wed Dec 03, 2008 8:18 pm
I am pretty sure moms truck already has the 318 in it. I was just wondering what tranny bolts to it so I can start looking for it.
PostPosted: Fri Jan 23, 2009 8:15 pm
theres a 3.9 that was made for years, even in a carbe, now its a 3.7 V-6 making 200ish hp
the 4.7 V-8 replases the 5.2, 318cc
the 5.7 HEM V-8 replases the 5.9, 360cc
my 0.01
the 318 EFI is a good engine, that can get fare mpg, around 17-20
a little more with a manual trans, but ill bet there all auto trans
OH ive seen newer and older 4 bangers to, but all newer ones are 4x2 short bed
this may help you
http://en.wikipedia.org/wiki/Dodge_Dakota
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Mon Jan 26, 2009 6:35 pm
Find a Donor truck if you can. It will save you from having to find all the little parts as you go. Sell the rest off when your are through.
PostPosted: Tue Jan 27, 2009 7:55 am
Thank you to every one that tried to help as it turns out the truck was a 97 and now it is wedged long ways between a power pole and a really big tree. So now I looking for another truck. Kinda a bad subject right now. If anyone hears about a cheap truck for sale in southern California please let me know. Thanks Again.
PostPosted: Tue Jan 27, 2009 6:02 pm
Sorry for your loss. :(
PostPosted: Fri Jan 30, 2009 12:35 pm
Im not even going to try and lie about it I build that truck three times for her and when she wrecked it this time I cried because one I just payed alot of money for it and two I knew I couldnt fix it this time. But anyways on to bigger and better things I am thinking I will buy a 2 1/2 ton 6x6 :twisted: and turn it in to a mudding road legel beast.
