It is currently Mon Jun 08, 2026 4:03 pm
PostPosted: Sat Nov 22, 2008 6:15 pm
We've got an '81 Luv 4x4, and the mahcine shop says the head is too warped to fix. I found two heads for sale in my area, but have no clue what will replace ours. Any advice is much appreciated!!! And, what to watch out for!! Thanks, please reply to this post ASAP!!!
PostPosted: Sat Nov 22, 2008 6:23 pm
76-82 are a direct fit in LUVs, and Isuzus for a few years after that. I think in about 84 Isuzu started putting the 1.9L motor in instead of the 1.8L so as long as it is a 1.8L G180 and not a 1.9L G200 the head from a newer Isuzu will fit.
There is one minor issue you might have to worry about. If your current motor has a mechanical fuel pump bolted to the head on the front right side, the hole won't be there on some older heads. The casting and bolt holes will be there through so it just needs some material removed and it would work.
