It is currently Mon Jun 29, 2026 5:06 am
 Post subject: V8 Header Question
PostPosted: Thu May 30, 2002 8:56 pm
Last year I purchased a 79 LUV with a 350, TH350, Ford 9". I have recentley rebuilt the engine, trans, cleaned up frame, and added step side.
Now I am ready to reassemble. I will be adding a new exhaust system. :? What type of headers are out there that will fit this combo? I really don't want to use the stock exhaust manifolds that it had. I was hoping to add 2.5 or 3 inch exhaust pipe. Not sure if it will clear or not. The previous owner pounded the 2" exhaust down to about 1" so that it would clear.
I hope to post pictures soon.
Thanks,
Mike
PostPosted: Thu May 30, 2002 11:05 pm
I'm 99% sure that you can still order the Hooker Headers from Summit Racing. Ask for Hooker part number 2140. They should be available with or without ceramic coating.
If you need more info or want part numbers for other parts such as Hooker's motor mount kit, check out the V8 Engine Swap article on the luvtruck.com web page under "Information".
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Thu May 30, 2002 11:08 pm
<edit> Nevermind, I'm losin it. Just realized that there's another post about this in Drivetrain.
Hey, it was a long day yesterday OK. LOL!
PostPosted: Fri May 31, 2002 5:12 am
the hooker headers are still available.
if summit doesn't have them try Jegs. 1-800-345-4545
I purchased mine a little more than a year ago.
PostPosted: Fri May 31, 2002 8:42 am
Thanks everyone. I appreciate the help.
Mike
PostPosted: Fri May 31, 2002 10:21 am
I know for a fact Summit has them in stock, I called to confirm pricing when I wrote the engine swap article a couple weeks back.
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Wed Jun 05, 2002 12:38 pm
Another thing to note on the header topic, is if you convert your truck over to coilover's on the front and lose the tortion bars this opens up header options. I have seen guys run just about any header they can find when the tortion bars are out of the picture. I don't have any specific applications to share though. Thanks
63 Nova
74 Camaro
Users browsing this forum: Google [Bot] and 74 guests
