It is currently Wed Jul 01, 2026 6:29 am
PostPosted: Fri Nov 14, 2008 8:36 pm
i have a 1980 Luv 2wd with a stock 1.8L engine and i was wondering what other trucks or cars have the 5 speed that would bolt up to my engine.
PostPosted: Fri Nov 14, 2008 8:39 pm
I just bought a chevy luv 76 with 5 speed transmision, let me check the what kind the tanny is, I will let you know soon.
PostPosted: Fri Nov 14, 2008 8:44 pm
dan have some extras for 200 Bucks check the post in this forum
PostPosted: Sun Nov 16, 2008 4:18 pm
thanks that would be great, another question did any of the luvs come with a 5 speed from the factory?
PostPosted: Sun Nov 16, 2008 5:33 pm
Luvtruck.com Wookie
1981+1982 yrs had the fiver.....
if you do the swap make sure you get the spacer (starter plate)from the donor vehicle it's a bit thicker than the four and it will waste your input bearing on the trans if you use the four speed plate.
TiLtEd wrote:
Boobies!!! :D
