It is currently Sat May 09, 2026 9:09 am
 Post subject: noisy tranny
PostPosted: Fri Oct 31, 2008 11:17 pm
i have a tranny that makes a lot of gear noise in every gear except 4th never pops out of gear easy smooth! shifting. well is like firm shifts its not like sloppy its tight. it sounds exactly like those vids of cars with straight cut gears. is it possibl its got parts in it? or do u think its just toasted. i was told when i bought the truck that it had about 500 miles on a rebuild
 Post subject: Re: noisy tranny
PostPosted: Sat Nov 01, 2008 1:37 am
Mine did the same thing for a few months until one day any gear except 4th would pop and clank.
When we pulled the trans, one of the bearings were toast. As in, the balls out of the bearing were in the bottom of the trans.
PostPosted: Sat Nov 01, 2008 12:12 pm
any ideas on where to get parts to rebuild it? i drained or opend the drain plug but no gear oil was in there! where do i go? any trans shop?
PostPosted: Sat Nov 01, 2008 1:05 pm
Since it was empty, I would just fill it with oil and see if it gets better. It takes 40wt motor oil. I'm not sure how much, it's in the manual.
