It is currently Mon Jun 08, 2026 6:45 am
 Post subject: smog pump?
PostPosted: Sat Oct 18, 2008 10:58 am
can I delete the smog pump on this thing? if so... how? also i need lowering tips until i can afford my bags....thanks for any and all help!
 Post subject: Re: smog pump?
PostPosted: Sat Oct 18, 2008 4:11 pm
Do you have to smog it where you live? If yes, then leave it on, and remove the belt.
If you want to remove it, all i did was take it off, and plug the vacuum lines where all the emissions gabage went on, save the ignition advance.
PostPosted: Tue Oct 21, 2008 11:53 am
"can I delete the smog pump on this thing?"
What thing?
PostPosted: Sat Oct 25, 2008 7:26 am
I dont need to smog it here.... I live in rural Idaho amongst the farmers so it will never get checked. 1980 luv 2x4, I took the belt off but would like to do away with the whole system. any help on what to do?
PostPosted: Sat Oct 25, 2008 9:06 am
If you do decide to get rid of your smog pump. You could sell to a CA Luv owner. We have to smog our vehicles that are 1976 and newer.
But Tundra is right about takign the belt off the smog pump.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 64 guests
