It is currently Mon Jun 08, 2026 3:04 pm
 Post subject: need new dash
PostPosted: Fri Sep 26, 2008 11:22 am
post resurrector
I need a new dash for a '80 luv mine is pretty trashed, so if yall find one or have one laying around give me a shout.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
 Post subject: Re: need new dash
PostPosted: Fri Sep 26, 2008 7:44 pm
Not to be rude but best of luck to you. Me and another member here got the last 2 dash's from Aus for about $800.00, no one else makes them and he wont make them anymore.
PostPosted: Fri Sep 26, 2008 8:44 pm
Your number in line is #48664, now serving #12. :P
PostPosted: Sun Sep 28, 2008 8:54 am
The dashboard that were coming out of australia, do we know why they are not making them anymore?
PostPosted: Sun Sep 28, 2008 10:07 am
i think best bet is the guy that scored the $20 oem new dash on cl is down to make repops but he needs help in doing so
PostPosted: Sun Sep 28, 2008 10:45 am
Nobody wanted to spend $800 on them.
PostPosted: Sun Sep 28, 2008 11:00 am
800 was a tough pill to take, but like drummer said only a couple of us in several years bought them. I would like to add, my dash is the first thing that people mention when they look inside of my truck, it does pull the entire truck together.
In my 76 LUV I have the proto type from AUS in it, it did take some work but I did get it to look correct.
PostPosted: Mon Sep 29, 2008 3:41 pm
duct tape and bailing wire pulls mine together lol
PostPosted: Tue Sep 30, 2008 6:25 am
post resurrector
dang that sucks, well I hope he gets that one of his reposted, it would be a deathmatch trying to get it.
BOOMER SOONER!!!
PostPosted: Tue Oct 14, 2008 1:12 am
Hey Tilted.... I just found tag # 14 ... lol
I've been reworking one of dashes w/ a cap from ebay
{ viewtopic.php?f=8&t=16900 }
What a project pieceing it back together 1st & then caping it
but i like working w/ my hands & have more time than money so i'm working it.
My question is NOW that some of you have Great Dashes... How are you protecting them ?
I'm even wondering if i should be covering up my plactic dash cap ?
_______________________________________________
PostPosted: Tue Oct 14, 2008 6:50 am
You probably should cover the cap. I have one that is starting to get a couple high spots in it. Like large pimples. The truck sat all summer in so ca, closed up, in the sun, with a dash carpet and a towel over it. I think the heat got it.
PostPosted: Tue Oct 14, 2008 9:20 pm
My trucks does not sit outside anymore since I put the new dash in back in the early 90s, and I dont use armor all on it anymore either, been holding up awesome for 15+ years now.
PostPosted: Fri Oct 17, 2008 2:49 pm
LOL i know what you mean. I cut out the center of my dash between above the cigarette tray, I am going to put in 2 switches, an inverter volt/watt display, and two outlets.
I don't care how it looks!
