It is currently Tue Jun 09, 2026 12:14 pm
 Post subject: 81 Luv vacuum lines
PostPosted: Thu Sep 25, 2008 8:37 am
I have a 81 4x4 gas Luv. Does anyone know where I can get a vacuum line diagram for this truck? Can't find one in my area. Also, does anyone know if reg gas affects the performance of the older trucks ? I'm thinking that with the change in octane levels and removal of lead in the gas today that performance may be affected. Thanks
 Post subject: Re: 81 Luv vacuum lines
PostPosted: Thu Sep 25, 2008 12:10 pm
are you sure it wasn't designed to use unleaded? my 1980 4x4 is marked "unleaded fuel only" above the gas fill area. I have the diagram out of a series 10 shop manual. I'm not sure if the 81 is a series 10 or 11, or if the emissions systems are the same. (mine has no emissions and is marked "non-catyletic" under the hood. If it will help I'll scan it and post it.
Let me know,
Zym
PostPosted: Fri Sep 26, 2008 7:05 am
And if that doesn't help, try IsuzuPup.com, since it's the same truck.
Users browsing this forum: Google [Bot] and 14 guests
