It is currently Mon May 25, 2026 12:32 am
 Post subject: 3.8 exhaust
PostPosted: Mon Jul 07, 2003 11:21 pm
anyone know of a 3.8 buick that DID NOT have a crosspipe. i am wanting to keep the stock manafolds on mine and am running into problems with the pass side pipe........mainly the fact it has 2 holes and both have shit in the way :x
thanks
PostPosted: Tue Jul 08, 2003 12:01 am
If you can locate a set of exhaust manifolds from a 77 odd-fire Buick, you can use them. The only mod needed to fit them is to grind some metal from the head because the drivers side manifold will hug the block and there's some interference at one spot. I've used the same manifolds on 4 different Buick motors. The original setup i had used the stock crossover that joined together below the starter and i had single exhaust. Going to a dual exhaust setup was a breeze. The drivers side exhaust crossed over to the passenger side of the truck after the tranny. Both mufflers are under the bed, positioned with the wide part of the mufflers going up and down, and the passenger side exhaust crossing over to the drivers side of the truck to help equalize the tube lengths. This is one way to skin that cat.
PostPosted: Tue Jul 08, 2003 12:07 am
i dont think i need the driver side manifold......it looks like it will clear fine. shouldnt hurt to just use the pass side odd fire manifold would it?
PostPosted: Tue Jul 08, 2003 1:21 am
If i would have thought it thru some more, i would have seen that! Yes, that would be the smart thing to do. And you would'nt have to remove any metal to fit that side. The trick is to find one. Good luck.
PostPosted: Tue Jul 08, 2003 12:51 pm
Just cut the body mount brackets off and run chrome exhuast along the frame.....lol, I think i'm going to have to go to shorties for my application
