It is currently Mon Jun 08, 2026 6:45 pm
 Post subject: K
PostPosted: Mon Sep 15, 2008 10:48 am
So my webber should be hear today is there any trinks to installing them?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
 Post subject: Re: K
PostPosted: Mon Sep 15, 2008 11:32 am
red teh dirktins
 Post subject: Re: K
PostPosted: Mon Sep 15, 2008 2:20 pm
Luvtruck.com Wookie
the redline adapters tend to come loose about every couple thousand miles.... when you bolt down the conical bolts (allen head) use a little loctite on the threads
TiLtEd wrote:
Boobies!!! :D
 Post subject: Re: K
PostPosted: Mon Sep 15, 2008 6:30 pm
well I cant get the dam thing to idel
79 4x4 1.8 liter
 Post subject: Re: K
PostPosted: Mon Sep 15, 2008 6:33 pm
Sure you plugged all vacuum leaks?
 Post subject: Re: K
PostPosted: Mon Sep 15, 2008 7:11 pm
yea I even ran propain around it
79 4x4 1.8 liter
 Post subject: Re: K
PostPosted: Mon Sep 15, 2008 9:27 pm
it keeps surging up down ?
79 4x4 1.8 liter
 Post subject: Re: K
PostPosted: Mon Sep 15, 2008 10:20 pm
That's the sign of a vacuum leak.
 Post subject: Re: K
PostPosted: Tue Sep 16, 2008 6:33 pm
Well I got it running but I am wondering dose the adapter plat have to be on a side?
79 4x4 1.8 liter
 Post subject: Re: K
PostPosted: Tue Sep 16, 2008 10:59 pm
HUH???????
 Post subject: Re: K
PostPosted: Tue Sep 16, 2008 11:39 pm
Are you asking if the plate has to go in with a certain side facing up? Are you thinking you installed it upside-down?
 Post subject: Re: K
PostPosted: Wed Sep 17, 2008 4:35 pm
dose the grove on the plate go on the primary side or the sedcodary side of the carburator
79 4x4 1.8 liter
 Post subject: Re: K
PostPosted: Wed Sep 17, 2008 6:27 pm
any pictures
 Post subject: Re: K
PostPosted: Wed Sep 17, 2008 9:37 pm
ctmandu wrote:
any pictures
:esurprised
 Post subject: Re: K
PostPosted: Wed Sep 17, 2008 9:41 pm
no clue to what he means 8O
 Post subject: Re: K
PostPosted: Wed Sep 17, 2008 9:49 pm
Im not sure about the Luv adapters, but I do know if you buy a weber kit with an adapter plate, you need to make sure the base of the carb is flat and the adapter plate itself was flat. I installed a kit on another rig and I had to flatten the base of the carb and the adapter plate because they were warped, brand new. Im not a huge fan of the weber stuff. When you look at the groove, it should be pretty straight foward. When you put it up to the base of the carb and look at it it should really look good one way and be off a little another way. I dont think it would matter a whole lot though, because its still letting air and fuel down the intake. If its backwards though it might not work as efficiently though.... I dont know this is just the experiance I had with a similar engine and I think I know the groove your talking about.
If its got tires, tracks, or t..s, its going to cost you money!
 Post subject: Re: K
PostPosted: Thu Sep 18, 2008 11:50 am
yea thats the wat I am talking about I was just wondering og the grove side needs to be on the secondary or the primary side
And yes it is a Webber kit
79 4x4 1.8 liter
 Post subject: Re: K
PostPosted: Thu Sep 18, 2008 1:07 pm
:popcorn:
 Post subject: Re: K
PostPosted: Thu Sep 18, 2008 10:56 pm
Well, its been awhile since I did mine and Im no expert by a long shot, but if I remember right one of the holes is smaller then the other, either the primary or secondary. The adapter plate, if I remember right, has a little hole and a bigger hole with the groove. Just put the adapter plate up to the base of the carb and try and line up the holes.
