It is currently Mon May 11, 2026 12:35 am
PostPosted: Mon Sep 08, 2008 12:21 pm
Anybody using a Weber 34 or Weber 32/36 carb on a truck that has stock A/C? :?:
The reason I ask, according to the Weber dealer, there is no consideration on either the 34 or 32/36 for the idle-up feature when using the A/C. On the stock carb, there's a solenoid that punches up the idle about 200 RPM when idling when the A/C is turned on.
According the Weber dealer, if you install either the 34 or 32/36 and turn on the A/C, the engine will die.
Just another quandry with converting.... Thanks all.
PostPosted: Mon Sep 08, 2008 8:09 pm
That's the price you pay for performance. Just rest your foot on the pedal when the A/C kicks on while at a stop.
PostPosted: Tue Sep 09, 2008 6:08 pm
That's a mighty high price to pay for something that doesn't fully fit the application. That's about as bad as Weber saying just set you idle up 200 RPM in the summer. :x I think Weber should come up with something that would work for the price they charge given it's a factory option. I guess they know they've about got the market covered for Luv's and there's not many more options.
I'm not after performance to start with; just a reliable carb that will fix my problem of a rough idle. I've rebuilt the Hitachi twice with no better results. I've checked for vaccum leaks and found nothing.
I'm starting to wonder if it could be the plate (not gasket) that sits between the carb and intake. The original one crumbled into three pieces during one of the rebuilds and I had a buddy who owns a machine job make me one out of aluminum using the old one as a template. There's a sleeve that fits into that plate that I'm wondering could be the problem. I'm thinking of taking it out just to see if it would help.
Trust me, if I could find a resolution for less than $320 (the cost for the Weber kit), I would jump on it. :lol:
PostPosted: Wed Sep 10, 2008 8:54 pm
Not sure how you could adapt this. Fast Idle Solenoid.
https://www.holley.com/46-74.asp
They used to use a electric solenoid that would push the throttle lever up when the A/C compressor is turned up. It was adjustable.
http://www.dougherbert.com/solenoidfastidle-p-22511.html
http://cgi.ebay.com/ebaymotors/CARBURETOR-FAST-IDLE-SOLENOID-WITH-BRACKET-A-C-HOLLEY_W0QQitemZ170260608372QQcmdZViewItem?hash=item170260608372&_trkparms=72%3A727|39%3A1|65%3A12|240%3A1318&_trksid=p4506.c0.m245
http://cgi.ebay.com/ebaymotors/68-89-Chevy-Corvette-GMC-Jimmy-Idle-Stop-Solenoid_W0QQitemZ250293611923QQcmdZViewItem?hash=item250293611923&_trkparms=72%3A727|39%3A1|65%3A12|240%3A1318&_trksid=p4506.c0.m245
You get the Idea
PostPosted: Wed Sep 17, 2008 5:43 am
Thanks for the info.
I understand. I noticed the price ain't cheap. $73 for a universal kit when I've already laid down $300+ for a carb gets a bit pricey for my wallet. If I go the route of a new carb I believe I'll tweak the idle up a bit in the summer as someone previously suggested.
I did disconnect the current solenoid on the hitachi carb, let the truck idle and turned on the A/C. The truck did not die so it may run w/out the solenoid.
