It is currently Thu Jun 25, 2026 11:43 pm
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Aug 29, 2008 6:46 pm
I like them all... :D
PostPosted: Fri Aug 29, 2008 7:57 pm
Good point. I like them all too. I should have used better wording. :D
My build thread.
PostPosted: Fri Aug 29, 2008 8:30 pm
hey 77 4x4 nice truck! what trans/transfercase do you have because the front driveshaft looks real long. is it a divorced t-case?
PostPosted: Sun Aug 31, 2008 4:13 pm
its a th350 trans im not suree what tcase from the diagrams i have tryed to match it up to it looks to be an IH tcase and it has a d35 front axle with luv brakes and the stock rear. i didnt build it so i cant be sure
No luv right now =(
PostPosted: Sun Aug 31, 2008 11:37 pm
Here is my '78. It's all stock except for being lowered. Right now I think I need to pull the head. I think it dropped a valve seat.
PostPosted: Mon Sep 01, 2008 6:34 pm
Here is mine. '74 Luv with BBC, Turbo 400, Ford 9" rearend with 4.56 gears. Aluminum interior.
PostPosted: Mon Sep 01, 2008 8:14 pm
Here's my 79 and some mods etc...
-3 1/4" stock floor body drop
-Everything shaved(firewall, handles, front bumper, tailgate, cowl, etc)
-Rebuilt 231 w/holley 4 barrel, w/350 trans & s10 rear
-Custom front tubs
-Custom rockers on the bed to match the cab
-Custom brake lines, vacuum lines, fuel lines
-Sheet metal bed w/spray-in bed liner
-Air tanks and fuel cell airbrushed
-35x20 rag top
-Driver side suicide door
-Custom mix metallic green
-Pinstripes on the pillars, hood, and tailgate
-17" escalade wheels painted black metallic w/polished lip
-89 Caddy tails
-Grant Kustoms roll pan
-Custom functionally cowl hood
-Sheet metal dash/console w/fiberglass skulls and airbrushing
-Fiberglass door panels w/skulls and airbrushing
-82 Celica seats re-upholstered w/black & green tweed w/green piping
-Solid Billtet Iron Cross steering wheel
-Thats off the top of my head, lol, here's some pics....
PostPosted: Tue Sep 02, 2008 12:06 am
PostPosted: Wed Sep 03, 2008 10:57 am
I also have a luv with a dana 30 and luv brakes(working on full width 1/2 ton axles now) My transfer case is divorced dana(not bolted to the trans) but i'm not sure what model. Is yours divorced?
PostPosted: Wed Sep 03, 2008 12:55 pm
i dont know much about 4x4s but if divorsed means trans and tcase are seperate units then yes
No luv right now =(
PostPosted: Thu Sep 04, 2008 10:33 am
Thanks, I' ve been trying to get seal kit for mine.no luck Sorry that i got off topic
PostPosted: Fri Sep 05, 2008 5:12 pm
bad pics gott them on my phone but best i got right now
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Sep 06, 2008 5:06 pm
JUST GOT IT ABOUT A MONTH AGO
PostPosted: Sun Sep 07, 2008 6:44 pm
Here she is.
Stats:
3in drop
Custom Rustolium Paint Job (not rattle can or rollar, just sprayed on)
HIND Hood scoop (just for show)
1986 1.9L Isuzu impulse engine
Paceseter Ceramichrome coated Header (not in picture above)
Weber DGEV 32/36 Carb
1984 Pup 5 speed trans
2005 Nissan Titan wheels with Federal 215/35R18
APC Black Suade Racing seats
Electronic Distributor, Cooling fan, 50 amp altinator, custom air filter base
Still in the works:
Offi Intake manifold
3.73 rear diff
Tonneau cover
Custom gauges
Custom Dash
Different seats (need more leg room!)
Hold on to your lug nuts, it's time for an Overhaul!!!!!!!!!
PostPosted: Sun Sep 07, 2008 8:02 pm
nice ill have to come see it one day if that’s ok
PostPosted: Sun Sep 07, 2008 11:16 pm
Nice looking truck rainman105. What's the hood scoop from?
My build thread.
PostPosted: Mon Sep 08, 2008 12:15 am
wow havent been on in a while(wrkin on buyin parts lol) good to see the thread has taken off!lol everyones trucks look awesome :D
6.0l ls1 swap th350
PostPosted: Tue Sep 09, 2008 5:02 pm
My 74 406 small block chevy, ford 9", pro street The engine pic is not current, I have it cleaned up now.
My 76 4.3 chevy v-6, 200 4r trans, ford 9"
PostPosted: Tue Sep 09, 2008 9:35 pm
Someone should plan a cruise in or somethin'.
PostPosted: Tue Sep 09, 2008 10:25 pm
i had one here but only 3 showed up..
