It is currently Tue Feb 03, 2026 5:52 pm
 Post subject: air bags
PostPosted: Tue Aug 19, 2008 3:18 pm
does anyone know how to instail air ride system :?:
 Post subject: Re: air bags
PostPosted: Tue Aug 19, 2008 3:21 pm
no one makes a direct bolt on for the luv.
YOu can buy parts and build your own.
Check out - http://www.suicidedoors.com for starters. :lol:
Most of there rear kits for the s10 are a close match for the luv frame, you can MAKE them work.
WARNING - I am not held responsible for all the money you will spend. :wink:
here are some members links to get you an idea of what your in for.
viewtopic.php?f=4&t=12675
viewtopic.php?f=33&t=13796
viewtopic.php?f=33&t=17523
PostPosted: Sat Aug 23, 2008 12:12 pm
thanks that helped alot but whats the best place to buy the stuff at
PostPosted: Sat Aug 23, 2008 12:22 pm
I'm bias casue i get a discount, but I think for air ride stuff, suicidedoors.com is the best quatlity for the money.
PostPosted: Tue Aug 26, 2008 3:51 pm
thanks man
PostPosted: Tue Aug 26, 2008 7:55 pm
what kind of of bags do i need for my truck and should i get a starter kit and what size air line
PostPosted: Wed Aug 27, 2008 7:06 am
that all depends on what your after.
larger line and valves will be faster lift and drop. So if you where gonna body drop it then i woudl suggest smaller line, if you want to hop the front, then larger line. I would recommend like 3/8's line and valves, not too fast on average.
Then you have to decide on valves, etc.
my favorite brands for valves are SMC's. Bags are Slam Spec. and any line as long as its DOT approved.
It's probably best to read up on tons of other builds to see how others have done theres.
Go here, http://www.s10forum.com, they have a HUGE section on bagged trucks, projects section, etc. And you'll find tons of info on different rear setups and such.
The rear kits for the s10 are only 1/2 inch wider than our frames on the luv, so consider you can buy an s10 rear kit and just flex out the frame rails alittle or mod them to fit.
If you still have questions after reading thru that site abit, just let me know. I'll try and answer them all without sounding like a sales rep. :lol:
PostPosted: Wed Sep 24, 2008 3:55 pm
thanks man
anytime. :D
