It is currently Mon May 25, 2026 11:56 am
 Post subject: gas gauge
PostPosted: Thu Jul 24, 2008 7:59 pm
need to get it working. i have a full tank and sometimes it reads half i have a 320 + trip planned for tomorrow would like to get it working i just noticed that if i'm holding the engine at high rpms it goes to full
 Post subject: Re: gas gauge
PostPosted: Thu Jul 24, 2008 10:23 pm
There's a multi-wire plug in connector on rear of instrument panel. Panel is held in by a few wing nuts on panel studs. A little shot of WD-40 will make it easier to carefully pull plug loose, without cracking panel's delicate printed circuit board. Just pulling loose after WD and re-plugging can make a big difference, cleans wire contacts. You can hose it off with electrical contact cleaner after removing to clean off WD or just leave it.
PostPosted: Fri Jul 25, 2008 2:23 pm
thanks i'll try that
Users browsing this forum: No registered users and 59 guests
