It is currently Fri Mar 27, 2026 9:50 pm
 Post subject: Truck is vibrating...
PostPosted: Sun Jun 29, 2003 8:59 pm
Hey everybody, I'm hoping someone could help me out or give me a little advice. Just yesterday my truck has started to vibrate pretty bad. It drives nicely until about 60 km/h and begins vibrating from there...anyone have any idea whats happening?
PostPosted: Sun Jun 29, 2003 10:20 pm
thats a hard one to answer, as there could be many things causing it to vibrate. (most comon) wheel weight might have come off while driving around. Hmmm,,,,bent driveshaft you been 4 wheelen lately? Maybe even a broken steel belt in a tire. These are some easy ones to rule out.
I hope this helps ya out some.
PostPosted: Sun Jun 29, 2003 10:53 pm
Sabin i should have said something about checking your U joints on the drive shafts front and rear too. As they to can make it feel like it wants to vibrate off the road at times.
PostPosted: Mon Jun 30, 2003 12:40 am
but for any of these problems shouldn't the truck be vibrating as soon as I go driving around? ...why would it start at 60 km/h?
 Post subject: bad vibrations
PostPosted: Mon Jun 30, 2003 2:10 am
PITA Old Fart
Vibrating at high speeds usually means the tread is coming loose from a tire. Check your U-joints, then your driveshaft, then check your tires closely, if that doesn't help, try seeing if it does it with the clutch in v.s. out to eliminate clutch parts/tranny problems as the cause. Hope this helps. Later :twisted: -TAZ
PostPosted: Mon Jun 30, 2003 12:04 pm
my truck did that. check your driveshaft to rear end attatchment.
the bolts might be loosening.
I didn't know to check mine and it threw the driveshaft.....that was a loooong time ago though....like 12 years....
03Cobra
PostPosted: Tue Jul 01, 2003 12:26 am
thanks guys, I'll have the truck in shop tomorrow and check all these things out.
PostPosted: Tue Jul 01, 2003 1:07 pm
ahhww man I"m pretty stupid. What I did was a couple of days ago I was messing around inside the cab and hit the gear shift into 4 wheel drive....so I've been driving around for 2 days in 4x4 without the hubs locked in and thats why it's vibrating.......I guess I should count myself lucky. I don't think that could do a lot of damage could it? I should be good I think.
PostPosted: Tue Jul 01, 2003 8:20 pm
see stuff like that happens when you have sex in the cab of a LUV :wink: :P :lol:
 Post subject: good vibrations
PostPosted: Tue Jul 01, 2003 9:25 pm
PITA Old Fart
Yeah larpy tell him. Don't have sex in a Luv 'cause you'll be lucky if all you get the shifter stuck in is 4wd. What were you THINKING? See just like your mommy said: "It's all fun untill someone gets hurt". Later :twisted: -TAZ
PostPosted: Wed Jul 02, 2003 6:29 am
i actually tried to screw my girl in my luv. it didn't work out in the cab but i got so frustrated i just bent her over tailgate :lol: :lol:
 Post subject: Oh great!
PostPosted: Wed Jul 02, 2003 2:40 pm
PITA Old Fart
Nice! Now when we go buy a truck we have one more problem to worry about. Those hard to get out tailgate stains and dents. (heh-heh-heh) Can't you kids behave? Later :twisted: -TAZ
PostPosted: Wed Jul 02, 2003 3:15 pm
thats why u sopost to do it on the bed not in the cab! :lol:
PostPosted: Thu Jul 03, 2003 1:24 am
mmyea she won't go in the bed unless I've pulled out a mat or something...to.."ripply" for her haha
PostPosted: Thu Jul 03, 2003 1:56 pm
PITA Old Fart
Why don't you just throw their butts up on the hood? It might warm them up faster and cut down on the foreplay time. (Then again, having hood rnaments removed is expensive.) Later :twisted: -TAZ
PostPosted: Thu Jul 03, 2003 1:57 pm
PITA Old Fart
Why don't you just throw their butts up on the hood? It might warm them up faster and cut down on the foreplay time. (Then again, having hood ornaments removed is expensive.) Later :twisted: -TAZ
PostPosted: Thu Jul 03, 2003 8:19 pm
luvs dont gots hood ornaments Image
 Post subject: i'm bad
PostPosted: Fri Jul 04, 2003 3:36 am
PITA Old Fart
Oh yeah, dey don't does dey! DUH! (sorry, tazzy having flashback Must be all dose drug I took when I was younger!...... Now, folks, I don't want you to think the old tazman used to be into drug experimentation...(In my case it was more like full-scale research!)... But anyways, let's be careful out there-the tailgate or hood you save could be your own! Besides - think of how hard explaining those suspicious dents to the neighbors will be! Later :twisted:-TAZ
