It is currently Tue May 26, 2026 12:11 am
 Post subject: suspension upgrade
PostPosted: Fri Jun 06, 2008 3:16 am
is there an independant rear suspension/differential setup on another vehicle that will fit my 73? how about for the front end?
 Post subject: Re: suspension upgrade
PostPosted: Fri Jun 06, 2008 4:22 pm
If you are good with a welder anything will fit. I am serious.
PostPosted: Wed Jun 11, 2008 9:46 pm
With alot of work try a 280Z Datsun it will handle all the V-8 power you can trow at it.
PostPosted: Sun Jun 29, 2008 11:59 pm
Rx7, Jag rear setups may work. I have seen Rx7 IRS in mini trucks before and the Jag rears are in streetrods. Corvair might even work if you want something really oddball or '61-'63 Pontiac Tempest have a IRS transaxle setup.
As far as the front foes, just have someone make some tubular controlarms.
PostPosted: Mon Jun 30, 2008 8:46 pm
Zactly! 8)
PostPosted: Thu Jul 17, 2008 2:28 am
How 'bout the front end outta another LUV 4X4?
PostPosted: Thu Jul 17, 2008 11:10 am
Here are some pics of the 300z rear and the mods to the LUV frame...
