It is currently Sun May 10, 2026 6:38 am
 Post subject: Decal removal?
PostPosted: Wed Jun 25, 2008 12:21 pm
Hello, I just picked up a 1980 4x4. After doing some reading on the $50 paint job, I'm going to give it a try, I certainly cant make this truck look any worse :)
What is the best way to remove the original 4x4 and stripe decals? I thought about 60 grit sandpaper, but it just seems like there has got to be a better way, maybe a solvent or something? A forum search didn't produce any results. Any ideas?
Heres a link to my intro post if you want to see a pic:
viewtopic.php?f=20&t=17437
 Post subject: Re: Decal removal?
PostPosted: Wed Jun 25, 2008 7:24 pm
what i found really good for my decals is to put nail polish remover in it then hit it with a heat gun or blow dryer and it pealls right up... well it did for me
PostPosted: Wed Jun 25, 2008 11:24 pm
http://www.autotrimdesign.com/Shopping% ... ctions.htm
PostPosted: Fri Jun 27, 2008 8:30 pm
I used one of those pin strip erasers on mine it took awhile but did a good job taking them off. You can get one at harbor house or just about any online auto body site. I'd like to have a set of decals to put back on after I paint mine I think they really look on the trucks.
PostPosted: Fri Jun 27, 2008 8:52 pm
ok you can use the oven cleaner that's
not needing heat. And I have used paint
aircraft stripper eats the hair off a walrus
azz.
