It is currently Tue May 26, 2026 8:39 am
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Jun 11, 2008 1:51 am
yeah I read alot about the engine spinning the wrong way but I have not verified anything yet since I have been super busy with some of my other projects I am swapping a 01 integra type r engine(b18c5) into a 90 integra so that'll be a heck of alot more easy that the luv for now.can anyone tell me which way the luv's drive shaft spins in forward gears? :?: :?:
PostPosted: Wed Jun 11, 2008 7:14 am
Look at the front of the engine. Where the pulleys are. See it if the engine runs clock wise or counter clockwise. That will tell you if it will swap or not ant keep the same rearend or not. You must do the same thing on the engine you are going to replace... If they turn the same, ok if different then no. Look at the pulley on the crankshaft .
KEEP your head, hands and clothes and all your stuff away from anything that moves!!
DO this at your own risk.!
You know why I said that....
PostPosted: Thu Jun 12, 2008 2:40 am
thanks alot I actually knew that but for some reason I was stuck in stupid mode thanks again. I'll be able to check my trucks rotation tomorrow... :D
PostPosted: Thu Jun 12, 2008 1:09 pm
I call it a senior moment. 8O
PostPosted: Sun Jun 15, 2008 5:44 pm
ok well good news everyone it looks like I am deffinetly going to be doing this swap.
I was worried for a few minutes there about not being able to use the stock luv rear end because I heard the engines spin the incorrect way but it turns out they both spin clockwise so yep yep I am happy again.
only bummer part is how much the ecu and getting it matched with a key is gonna cost along with the gauges
the gauges are going to cost me about $1000
the ecu is about $150 on ebay
the reflashing of the ecu is going to cost about $150 from a place 4 hrs away
anyone have any cheap places for electronic gauges I preffer autometer ultra lite
I need a tach 5" or 3 3/8 that goes up to 10k
speedo thats 5" or 3 3/8 that is electrical not cable driven and goes to 200mph
oil pressure 2 1/16"
fuel same size
volts
water temp
PostPosted: Thu Jun 19, 2008 2:10 am
ok well just some news on what I have done to my luv
shaved the door handles and locks(just need finishing work to be done)
removed about 300lbs of stuff not needed in or on my truck(bumpers heater core bench seat etc)
removed the gas tank to make way for my fuel cell
lowered in 3inchs
removed the bed to set up my pass through sub box
removed the stock mirrors I like them to a point but want different ones does anyone have any suggestions??????????????? I will try and get pics up but I dont know how
PostPosted: Thu Jun 19, 2008 12:53 pm
If you are going for a hotrod look I like peep mirrors
http://www.tperformance.com/street_rod_store/mirrors_and_accessories/clamp-on_outside_mirrors/
PostPosted: Thu Jun 19, 2008 3:51 pm
do you know of any luvs with those mirrors on them w/pics? I am not too interested in them but I might change my mind if they look good on the luv but I gotta be able to see out of them well too
I am kinda going to go with some import looking parts on the truck but not over do it lol
PostPosted: Thu Jun 19, 2008 4:58 pm
rodeobob wrote:
ret1614 wrote:
Sounds like you've got about the same problem as I do. I was gonna try to put a Chevy Corvair engine in a V-Dub. The engine spins the wrong way. One of the solutions is to re-cam the engine so it'll run backward. Just make the valves operate to the time of a reverse spin. Of course the accessories wouldn't work, unless they can spin backward...
I don't know, but a truck with 4 speeds of reverse sounds pretty original!
Ask a VeeDub transmission guy.
You can mount the diff together wrong by accident and that gives you 1 fwd and 4 rev gears with the std VeeDub motor. :wink:
My mate did it by accident when he was a young tacker.
I think its pretty common to swap shit about for making desert racers etc.
Bob.
I have done this several times when I worked at a VW dealer.
PostPosted: Thu Jun 19, 2008 7:25 pm
PostPosted: Thu Jun 19, 2008 10:48 pm
Makes me wonder what happend to those magazine trucks.? That one (Azusa) is just up the road from me.
I also wonder where all the headlight and bezel and grills from those trucks went back in the day.? Probably in the trash. :cry:
PostPosted: Thu Jun 19, 2008 10:54 pm
thanks for the pics would apreciate more. how did you get the pics to show up on there?
PostPosted: Fri Jun 20, 2008 10:20 am
Ok
How about some of these?
http://www.streetsceneeq.com/mirror.asp?mi=6
I have a set on my truck that look like the ones on your truck pic
PostPosted: Sat Jun 21, 2008 1:05 am
wouldnt work for my truck but they look good
PostPosted: Sun Jun 22, 2008 12:26 am
i use smugmug some use photobucket to host pic then put them in the body of what your typing and click img it will take care of it.. also do a search for how to do pictures, they is a how to on here,thats the only one i have with those ... you cam click on my link and you can look at lots of stepside luvs from back in the day and newer ones
PostPosted: Sun Jun 22, 2008 8:07 am
I first will say I never did an engine swap, just replaced it, but I happen to have a good running van with a FWD V6 3.0 in it. I wonder if it could be modified to go RWD in a Luv. BTW, this is a Dodge Grand Caravan with a Mitsubishi engine. It's fuel injected, and run with a computer.
I hope it's okay to throw this out here Savageluv. I use Photobucket for my image host.
'78 1.8L 4-speed Fleetside
Image Image
PostPosted: Mon Jun 23, 2008 2:35 am
thank you step-side I thought you could use photobucket cuz I did put pics up like that once b4.
and addicted dont worry I am interested in all kinds of swaps thats a pretty bad ass swap to have lol and a v6 non the less there is a mr2 running around somewhere that has a caddy northstar engine in it and it sounds mean lol
now process is going to be going even more slowly because I have two projects that are my own and like 3 others lol I just bought a 90 integra 4dr automatic needless to say it wont stay auto for long lol
PostPosted: Tue Jun 24, 2008 12:27 am
ok here is a bunch of pics of my truck of whats up with it lol
PostPosted: Tue Jun 24, 2008 12:29 am
PostPosted: Tue Jun 24, 2008 12:30 am
