It is currently Sat Jun 27, 2026 10:46 pm
 Post subject: Acc. pump on weber
PostPosted: Sat Jun 21, 2008 7:55 pm
Does anyone know where the acc pump on a weber gets the fuel? There are 2 small holes on the inside of the bowl just under where the pump diaphram bolts on the outside. I think the one closest to the fuel inlet is where it goes but I can't get air to pass through to the diaphram. If it is clogged I can drill it out but I'm not sure there is suppose to be a hole. Or is the diaphram even suppose to be wet?
 Post subject: Re: Acc. pump on weber
PostPosted: Sun Jun 29, 2008 4:45 pm
OK,,,,No body was able to step up and help with this one but I was able to figure it out. The hole on the inside of the bowl IS where the fuel goes to get to the pump. My problem was that I wasn't getting any fuel and the hole doesn't go straight through from one side of the bowl to the other so you can't just run a wire through (I use a cutting torch tip cleaner to clean small holes). I was really getting pissed so I decided to take the propane torch to it :evil: . I got it hot enough to melt the rubber tip on my air hose but, eehaw..... now my pump gets fuel and works :D I put the carb on my truck and it works, now I just have to get the linkage and hoses worked out.
So if anyone want advice on how to take a torch to you carb just let me know, lol.
Users browsing this forum: Baidu [Spider] and 33 guests
