It is currently Wed Mar 18, 2026 11:44 am
 Post subject: RAM 50
PostPosted: Sat Jun 14, 2008 10:09 am
ok here comes about the most retarted question you have ever heard
Well i have a Dodge ram 50 4x2 and it hesitates bad and i am told it is some kind of pump thing in the carb, so my question is.... i have a stock GM carb from a sbc thats in pretty good condition, will it fit, and will it work ok?
or will it pump out way too much gas? and if it does, cant i jus set the idle jet down and it will be ok???
please help me :eugeek
 Post subject: Re: RAM 50
PostPosted: Sat Jun 14, 2008 10:18 am
Is this the small D50? If so it's built by Mitsubishi. If it's the big ram truck and has the slant 6 it has a one or 2 barrel Carb. If it's the v8 version, it has a larger 2bbl or a 4bbl Carter. So, which one do you have?
PostPosted: Sat Jun 14, 2008 10:24 am
its the little one, its got the little 2.0 4 banger with a 2bbl carby on it
lik ethis but not extended cab and diff color
PostPosted: Sat Jun 14, 2008 10:48 am
Your gm carb most likely will not bolt up...
PostPosted: Sat Jun 14, 2008 10:57 am
Nope,not even close.
Does your carb look like this?
File comment: Mikuni carb
The Mikuni carbs have about the same problems as the Hitachis.
Probably the accelerator pump.
Your best bet is of course,a Weber.
PostPosted: Sat Jun 14, 2008 11:29 am
Mitsu carbs are special, I am a factory trained Mitsu mechanic, trust me.
PostPosted: Sat Jun 14, 2008 11:44 am
looks jus like that!
so luvrv8 whats your best bet as what i should do???
a weber?
PostPosted: Sat Jun 14, 2008 11:48 am
Find someone experanced in that exact carb, they are easy to screw up and diffacult to get right.
PostPosted: Sat Jun 14, 2008 12:24 pm
will a weber work
PostPosted: Sat Jun 14, 2008 12:29 pm
I had a Weber on a Mitsubishi 2.0 at one time and it ran great.
It was a circle-burner and I did not have to worry about emissions either.
I have no idea what model it was.
PostPosted: Sat Jun 14, 2008 2:10 pm
yeah i dont have to worry bout emissions or any thing just want it to run good
PostPosted: Sat Jun 14, 2008 3:08 pm
Look up the Weber site or a speed shop site and see if a kit is available for it.
PostPosted: Sat Jun 14, 2008 3:51 pm
I would go the same route as with the LUV trucks.
Get a Weber off of e-bay used,rebuild it.
The adapter plate will be different,but is available I'm sure.
I'm not sure about the linkage as the Weber was already on the engine when I got it.
I do remember switching from the Weber to a stock carb was no problem though,keep in mind this was on a race car and I didn't have to worry about the vacuum lines so much.
PostPosted: Sat Jun 14, 2008 6:18 pm
Picking up a used weber and a rebuild kit on ebay, then hunting around for the cheap adapter plate you can find is the right way to go - for sure. For what you would be expected to pay for a brand spankin' new carb with the adapter plate and gaskets all in a kit - you could probably buy 2 or 3 of everything...lol
You basically have two choices of decent carbs - the weber 32/36 or the weber 38/38. The 32/36 IMHO would probably give you great gas mileage but not as great performance as the 38/38. The 38/38 will give you great performance, the air/fuel mixture can be adjusted better than the 32/36, the 38/38s have mechanical secondaries that can be adjusted (if you want to - if not just leave them in the stock setting), and the difference in gas mileage between the two carbs IMHO is not really worth mentioning.
Since your engine is a 2.0, it should handle the 38/38 fine, and it will do OK with the 32/36 but IMHO it would be a bit under-carbed and slow off the line.
The last time I looked for used weber carbs on ebay (for a friend of mine that was at work at the time with no internet access) recently, the used weber 38/38 carbs were actually a bit cheaper than the used weber 32/36's were. And so were the 38/38 rebuild kits. This is probably due to the fact that the 38/38s aren't as common or as popular as the 32/36s are - but IMHO the 38/38s are a way better carb. Both carbs have identical bolt patterns, so they both use the exact same adapter to bolt on to your intake.
It's your truck - so you get to choose...lol
(BTW...don't get me started on Mikuni's POS PITA carbs.Those things were a freakin' nightmare to tinker on and try to get adjusted right as they got older and got more worn out...lol)
PostPosted: Sun Jul 06, 2008 1:50 am
ok so some one was saying they were a dodge mechanix or sometin? so! whaqt tranny is in here and what other motors will bolt directly up and be easy for me to do over a few weeks? i want a v6 if i can but if i cant what else wil bolt right up? i need more power and am on a budget :twisted:
PostPosted: Sun Jul 06, 2008 6:53 pm
What no Holley 4 bbl carb for it. :cry:
PostPosted: Sun Jul 06, 2008 7:19 pm
There are a few other engines that will fit, but you wont notice any difference in power. If you want more power then look for a truck with a V-8 or something like that. Sounds like you want to re-invent the wheel. I have a LUV with a V-8 and a V-6 but I did the swap for fun. I do drive a D-50 with a 2.0 as a daily driver when I am not in my duelly.
PostPosted: Tue Jul 08, 2008 2:07 pm
well i know that they came with 2.0 or 2.2's and i was wonderin if like i could swap a 2.2 in and use the 2.0 head for more compressoin? wouldnt that give it a lil more? well obviousley with a weber and header?
PostPosted: Tue Jul 08, 2008 6:22 pm
Different motors and the heads will not interchange. Like I said a well running 2.0 runs plenty strong, I can hit 100 MPH all day, what more do you want?
