It is currently Tue Mar 24, 2026 8:12 am
PostPosted: Fri Jun 28, 2002 6:58 pm
i need alower numerically gear ratio for my new toy i just bought a1980 luv for 300.00 ,48000 orginal miles,. ice cold air i been told its a 1.8 isuzu motor 4 speed gear box .iam not sure how many rpms i am turning at 60 or 65 mph but i know its more than i like PLEASE CALL ME DRAGBIKE BILL AT 727 579 0702
PostPosted: Wed Jul 03, 2002 8:30 pm
see this post
Apparently the trucks equipped with automatics have a higher ratio (numerically lower number). You could also swap in a S10 rear axle.
 Post subject: Gear ratio's
PostPosted: Thu Aug 29, 2002 2:43 am
Hello drag bike bill
All LUV's to my knowledge came with 4.56 rear ends unless it has an automatic tranny then it got 4.10's. I have'nt seen too many LUV's with the auto in it but it's worth a shot. You could do like Ben said and get a rear end out of a S-10 they came with gears anywhere from 3.08s to 4.10s depending on year and tranny. hope this helps.
Dave
PostPosted: Mon Sep 09, 2002 5:35 pm
Hey guys,
I have an automatic truck with a 4:10 geared stock rear end.
My question - is the stock rear end as stout as an S-10 rear end?
If so I am gonna leave it. Until it breaks anyway.
Next, does anyone know if anyone makes a mini spool for a stock rear end?
And finally, are the stock axles held in with a c-clip and if so, is there a c-clip eliminator out there for it?
Thanks
Giles5
 Post subject: Rear end
PostPosted: Tue Sep 10, 2002 1:15 am
Hey GILES5
First Yes the stock axle from a LUV is quite a bit stouter than an S-10 axle, The LUV axle is a 1 peice housing with a third member drop out carrier. The S-10 rear end is a gm coporate 10 bolt C-clip unit.
Second I have seen spools in the LUV but don't know of where to get them.
Third as I said before the LUV has a drop out third member carrier. No C clips there for no need for eliminator kit.
Hope this helps
Dave
PostPosted: Tue Sep 10, 2002 8:59 pm
Hey Dave,
Thanks for the info...
I called Strange Axle Co today and they said that they didn't make a spool for a luv rear end. They did give me the number for a truck racing company in Detroit ....Reiter racing 800-522-2707.
They were very helpful and told me that the luv rear end is a mitsubishi (spelling sucks) rear end. He said "just weld it up until you break it and then replace it with something a little stronger". What a concept :? But very honest!
At least if i break an axle it won't pass me down the track :D
Giles5
