It is currently Tue Jun 30, 2026 7:54 am
PostPosted: Fri Jun 06, 2008 10:05 am
Yesterday I was driving and my truck started to overheat. I made it to my destination and I poped the hood when I saw that my truck had blown radiator fluid everywhere. Today when I looked at things a little closer I found that my center pulley with the fan blade was loose. It moves like theres no tomorrow. I dont know a thing about motors but I know that it shouldnt be like that. Does anybody have any idea what it might be? is my motor trashed or is it like some type of bearing that can be replaced??? I also noticed that it has a constant drip of antifreeze below that pulley. maybe that is the reason its blowing coolant everywhere?
Thanks for helping
PostPosted: Fri Jun 06, 2008 11:57 am
Sounds like a water pump to me brother. Shouldn't be too expensive to replace. As for the motor it depends on how hot you let it get.
PostPosted: Fri Jun 06, 2008 1:18 pm
i no expert on motors either but i have dissasembled and put it back together more than once :wink:
so the better mechanix correct me if im wrong,
fan runs off of the water pump, so that could be loose causing the fan to be wobbling, and the water Will leak out if is not sealed completely
PostPosted: Fri Jun 06, 2008 1:20 pm
how long did you drive it after it over heated and about how hot was it when you noticed it?
PostPosted: Fri Jun 06, 2008 2:31 pm
I have had my motor REALLY hot before (Thermostat), and it didn't really hurt it any. Are you saying that the pulley spins freely like it isn't connected to the belt? All you have to do is tighten the belt at the alternator, then. Otherwise, just replace the water pump.
PostPosted: Fri Jun 06, 2008 4:24 pm
Sounds like a water pump is needed.
PostPosted: Fri Jun 06, 2008 8:46 pm
I didnt let it get to hot it just caught me off gaurd. I really appreciate all of you replying to my message it helps to have you guys and this web page. I just wish I knew more so that I could help others with thier problems....lol
PostPosted: Fri Jun 06, 2008 10:33 pm
Dont worry about it, we were all in your shoes at one time or another.
