It is currently Sun Apr 05, 2026 12:35 pm
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
 Post subject: Re: $50 paint job
PostPosted: Thu Feb 21, 2008 5:35 pm
Well like I said before I used regular auto hardner in my van sycle paint but sprayed mine after mixing with regular auto paint thinner.
Yes after it fades you can buff with polish and compund but after so many times you will run out of paint to buff. Each time you buff with compound you will lose alittle more surface paint. Still it should look good and last for awhile.
PostPosted: Fri Feb 29, 2008 11:36 am
drummerforhire wrote:
nukeday wrote:
drummer, what's on the hood? What did you prime with before you started rolling?
Looking good 8)
On the hood, actual automotive paint. Its about 10 years old, but it wasn't taken good care of. My grandfather had it for about 7 years and let it sit in the weather.
No primer. Just rustoleum. The rustoleum is designed to go on whatever, so hopefully it does what it should.
How goes the Rusto job?
FIAA: Color Guard
PostPosted: Fri Feb 29, 2008 7:31 pm
It's going slowly right now. I've got another couple of coats on it, but I've had to go back to work. I'll try to work on it more this weekend and maybe get some more pics up.
PostPosted: Wed Jun 04, 2008 8:13 pm
Any progress?
FIAA: Color Guard
PostPosted: Wed Jun 04, 2008 8:34 pm
My rusto job:
viewtopic.php?f=10&t=17191
PostPosted: Thu Jun 05, 2008 9:26 am
Dudeus wrote:
Nice work :smt023
FIAA: Color Guard
PostPosted: Thu Jun 05, 2008 7:27 pm
We used to use something called fish eye remover. This was before 2 stage paint....
PostPosted: Thu Jun 05, 2008 8:42 pm
Did you paint from top to bottom, bottom to top or how?
PostPosted: Thu Jun 05, 2008 8:49 pm
I wonder what one of these would do? You need a compressor
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43430
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90977
Those might just make the cost too much....
I love this tread.... Any one see a Maroon color?
I need to go from UT Burnt Orange to Aggie Maroon and white... My wife works at TAMU I get funny looks when I drive my truck around campus. 8O
PostPosted: Fri Jun 06, 2008 10:04 am
Roll it brother.... no need for compressors, overspray etc. :smt023
http://rollyourcar.com/default.aspx
FIAA: Color Guard
PostPosted: Fri Jun 06, 2008 10:29 am
Here is a video on roll on primer vs spray on primer.
http://video.google.com/videoplay?docid=-8769090549868663214&q=&hl=en
Here is one just on the roll on primer.
http://video.google.com/videoplay?docid=455967880138754811
Not quite the same thing but it makes you go hmmmm :)
A link to questions on a primer
http://www.basfrefinish.com/vta/R-M/faqs.htm
Q) What R-M primers can be rolled on?
A) DP20 2K Urethane Primer, DP21 Color-It Primer, and DP200 Low VOC can be rolled on using approved BASF Roll-On Primer products.
Looks like a lot of companies have a roll on primer. I am sure it is only a little time before they have roll on top coat.
I was reading on something, may be the mopar site, that before air compressors were around or common, they would roll on automotive type paints... I guess this is a revival of a old way on doing things. WOW... Still have a ton of stuff to read... The Morpar site may make my eye hurt...
GREAT POST!!!!!!
This one needs a sticky or a post of how to's
PostPosted: Mon Jun 09, 2008 10:41 am
I might have to go for a look at my local paint store and see what all this paint talk translates to down here.
Good job guys, those trucks have come up a treat.
Here here on the cream truck thing. I kinda want to keep it original but the Mrs has other ideas.
I heard an old wives tale about some old guy who used to pretty much throw a tin of paint at a car and then use the garden hose on a dribble to make it go all flat.
Thats the thing, theres a lot of proceses about that used to be everyday happenings, with technology they get long forgotten. Untill some young fella happens to stumble on it again.
Bob.
PostPosted: Mon Jun 09, 2008 12:36 pm
I think they have had to go to water based automotive in California.
PostPosted: Mon Jun 09, 2008 3:28 pm
GREAT POST!!!!!!
Honestly, if you have a somwhat decent base. You can repair the dings, rust etc. then spray prime those areas. The rest of the paint can be lightly sanded and feathered just to give the roll on a good surface to adhere to.
And yes on the old timers rolling on paint, a friend of mine has been into auto restoration for a long time and told me, back in the day, that's how they would paint cars. Several, several think coats of laquer based enamel, builds up to a deep shineable surface. Kinda like kiwi'ng the hell out of a ragedy pair of combat boots. Put enough work into it and yes you can polish a turd :)
With enough coats, the car could easily be repolished to showroom condition. Some guys still use this method for auto show cars
FIAA: Color Guard
PostPosted: Tue Apr 20, 2010 10:41 pm
have u seen the 3 years after holy cow im gona paint my luv like that
75-luv mikado-V8 350 soon
Users browsing this forum: Bing [Bot] and 45 guests
