It is currently Thu Mar 19, 2026 9:53 pm
PostPosted: Sun Jun 01, 2008 5:11 pm
Hey, ive got this plan to put a 345 hp ls1 engine with the t56 6-speed transmission and plan on just shortening up the driveshaft and use the aluminum one off the trans-am but what rear end would fit in the back and still hold up to that much torque because ive heard that the luvs rear-end is weak. And what should i do about brakes since there kind of important?
pain is just weakness leaving the body, and failure is just a chance to try harder next time
PostPosted: Sun Jun 01, 2008 11:00 pm
I like Ford 9 inch rear ends, some like and run a 12 bolt. There is no one rear end only, but the stock one will have to go.
PostPosted: Mon Jun 02, 2008 8:55 am
the stock will hold awhile but it will go sooner or later, i have a 9 inch it works just fine.
